PIP Sensor module for distributor
#107
#108
#111
Long time, no talk Subford!
Subford, never posted my results, but I have them! Have had them for quite a while. Took my upper intake off to check injectors because we were at our wits end, held fuel rail up while turning key to ON so fuel pump would run, and boom, injector #6 was dribbling. Replaced. Problem solved. So now, many months later, I still have the vacuum to the EGR plugged, but truck runs and drives really good. Except, I now have another problem as to where I have an (I want to call it intermittent) slight stumble/misfire feeling when idling, mainly after I rev the motor, on its way down. I feel the cab shake. I'm still leaning towards the PIP sensor being... failing? Any guidance would be appreciated!
#113
I have very similar symptoms on my 93 ford f250 with a 460. I have tried everything i can think of but i just came across your thread and a possible pip sensor fail makes sense to me. Have you tried replacement and did it work? I have an incomplete thread on this topic as well.
#114
Hey man, unfortunately i sold the truck. But the man I sold it to have had 0 problems with it. I never replaced the distributor.
#115
I'm thinking that I have a bad PIP sensor on my "95 F-150 4.9L.
My problem is that I was driving my truck and it just died going down the road. At first I thought that it was a fuel pump problem but it runs about a second every time that I turn the key on then stops. I have no fire from the ignition coil. I watched a couple YouTubes and found one with Scanner Danner and Eric the Car guy troubleshooting the same truck as mine I believe. When he was checking the ICM input from the PIP it read 10 volts setting still with the key on and was supposed to drop to 4 or 5 volts when cranked. Mine doesn't have the 10 volts to begin with. The PIP is getting 12 volts at the distributor but no voltage seen on the output wire. I guess that I need to verify continuity and no grounding in that conductor from the distributor to the ICM. I'm going to try do do that and look under the distributor cap today between bus routes. I retired from Carrier and am a local school bus driver now.
I have ordered an INNOVA 3145 Ford Digital OBD1 Code Reader to get the codes but it'll be the weekend before it arrives.
I'll let you know what I find. Any suggestions on what to check?
I found a very good website on troubleshooting this.
https://easyautodiagnostics.com/ford...module-tests-1
But I got stopped because I can't get my hands on a simple 12 DC LED to make the tool that he uses in Test #7.
https://easyautodiagnostics.com/ford...module-tests-5
I do have a Logic Probe that I haven't used. Would that do the same test?
Thanks for your time and help,
Joe
Joe
TexasGuy001
06-03-2018 05:44 PM
Tim Hodgson
Electrical Systems/Wiring
32
10-01-2017 09:54 AM
Cletus98
08-16-2016 03:17 PM
autox65
07-31-2016 05:27 PM
