Dip stick tube and dip stick
I'm trying to locate a dip stick tube and dip stick for my 460 that I'm putting in my '78 F250 4x4. The pan is rear sump out of an '85 F250 and is threaded. Local Ford dealer only shows front sump pans on his computer. We also went up and down several years and tried E250's with no luck. Anyone have any ideas?
Thanks
Thanks
I take it that you don't have the dipstick and tube from that 85 F250? If you do have it, use it, it came with that motor. In the 70's 460s were only put into 2wd trucks. For some reason the 2wd trucks use front sump oil pans. 4wd's need rear sump. Putting a 460 where a 351M/400 used to be is a common swap in 77-79 4x4's. L&L seems to specialize in the goodies needed for this swap. A van dipstick would be funky as they are designed to come all the way forward and above the motor to be accessed by the van hood.
hp246 I did a search on that site and found this.
http://broncograveyard.com/bronco/i-..._429_-_460.htm
I'm going to call them tomorrow but I think you helped me find the end to my dilemma!!!
Thanks
Thanks
How bout this one?
http://broncograveyard.com/bronco/i-...e_assembly.htm
If not, you might want to try these guys. I've dealt with them and they are pretty knowledgeable about everything Ford related.
BEN WHEELAN
11-04-2016 06:54 PM
1949f1
05-04-2016 05:11 AM
arrowheadfred
17
04-13-2012 01:00 PM
lifted77f250
08-03-2006 06:26 PM
