Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Lowering Kits
Overview of popular modifications to customize your truck
Aim/DJM lowering kit thread
#181
Surely I would think by now that AIM has fixed whatever problem they had. If they have had all the complaints and such as posted by people in this forum, then I just don't see how they can keep selling the same product and not think they will get a complaint. That makes absolutely no sense to me.
Yes, please report back in this thread and let us know how it turns out. I think if you get the right parts for your truck, you will be ok. There are differences between power steering and manual steering and also the leaf spring setup on certain trucks. Just make sure you get the right parts. Hell, I would drive my truck there and have them look at it and give you the right parts.
#183
#185
Mark, I cut 1/2 coil with my DJM beams and it seems to be fine. I suppose it depends on how worn your coils are and what engine you're running. This pic is with a fuel injected 5.0/AOD
As for checking the pinion angle, Tremec has a "Driveline Angel Finder" app for your phone. I've downloaded it but haven't used it yet.
#187
#189
I used the DJM rear lowering kit that replaces the front spring mounts and rear shackles. I also bought their shorter rear shocks. With their kit you have a couple of different height choices.
#190
Cambrr
Drop beams can't be bent. Camber adjustment is accomplished by either shimming or cutting the coil springs.
#191
#192
Bagging I beams
I am very new to this site. I have a few questions. First of all, I have a 71 F250 2WD. I am not interested in converting to a F100 suspension, just wanted to get that out of the way. My plan for this truck is unique. I am going to remove the overloads, and axle flip the rear with a large C-notch(and possible shackle flip/lowering shackle). I want the rear to be as low as i can get it, while still using the factory leaf springs, as I still haul occasionally.
I will be installing Chassis Tech drop beams and bagging the front. This will allow me to get her low but still be able to raise it and drive, as well as adjusting camber.
My question is has anybody used the bag brackets Airbag.com supplies for dropped i beams?
Here is the link for the brackets:
Trust The Air Suspension Ride Pros; Find Exclusive Deals on Hot Rod Suspension, Lift Kits, Lowering Kits, Lambo Doors, air springs, air bags, Billet Wheel Adapters, Towing Kits, Air Shocks, Air suspension Lift Kits
#194
You got it. I sold my bagged 65 GMC pickup and wanted another project. My gmc was bagged front and rear with a 4 link. To be honest, it was badass, yet utterly useless. I want a truck that I can still pull a boat if I feel like it. I want a damn truck!!!! A very low to the ground truck...
#195
aim djm lowering thread
hey guys called up djm suspension the other day and when I asked the guy about pinion shims he said they did not have them and that I don't need them I am almost sure i told him my truck is a longbed I am confused now some of the guys on here say it should be at original specs for the pinon angle I don't want vibration issues I want to do it right first time around anyone on here ever done the front and back djm drop on a longbed thanks in advace for any and all advice
