I won't make any statements, just ask questions. The thoughts are just to show how complex the 6.0 is. YA READY?..........If you delete the egr (closed off up-pipe, disabled egr valve), will the IAT sensor relay colder or hotter intake mixture to the pcm? Remember, IAT is an input for boost. With a deleted egr, what does the map sensor say? The pcm will cycle the vgt to look for changes in the values of the sensors related to boost (including egr). When theres a discrepancy, the pcm will default to a set reading for all of them (sound familiar?). The inferred ebp of the 03 and early 04 is relying heavily on IAT, MAP, EGR, EOT for its calculations. The pcm, upon seeing no temperature change in the IAT with boost and load changes, will do what with injector duty cycles?
__________________
ase master tech--fmc master tech81 f150--300 4x4
This post (and at least one similar post from the distant past) is why I have chosen to NOT delete the EGR system until I run out of warranty. At that point, I will install a custom tuner that properly accounts for these input parameters. Until then, I will (as meticulously as possible) watch over my combustion system components.
I sure understand why folks do it though - it is a source of so much "pain". I know that you have often said in the past that you should "get to the source" of the problem when you experience oily, thick soot that clogs up the EGR valve. I 100% agree. However, this is hard to do w/ the complexity of our engines - even quite a few dealership mechanics are not that good at it either.
I know from all the forums that there are many "stock" 6.0L trucks now making it to the "200k + mark" w/ original EGR system and original injectors. So it is possible to have reliability with an EGR system. It is just absolutely critical to keep your combustion system (and your EGR system) functioning well. There are just so many things that can go worng ............
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
I will give it a go..But go easy on me Vince remember I am a bricklayer.The IAT2 will read hotter since there is no cooling effect from the EGR cooler though in high egt situations the reading could be lower.MAP would read lower as there is no exhaust pressure,the pcm will over fuel the injectors in order to try and get all readings to get with the program.
__________________
Tony 03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
The IAT2 (yeah you're right) will read hotter from the onrush of hot exhaust gasses entering through the egr valve. Now, with a delete, the pcm is expecting to see this hotter temp, but its not there. So, whats wrong with "Just get a dummy egr valve and lay it on the intake" (I know you've heard that one). With a delete, will the map reading be higher than expected, lower, or right on?
__________________
Give the master tech 5 stars. One thing most don't realize is that if you DON"T run a programmer to recalibrate for EGR delete is that the PCM will go insane and you most likely will still have problems. It's not as easy as unplugging switches and capping off pipes. There's a LOT more involved.
Vince.....have you ever thought about going into the tuner business???
__________________
Ford Makes It, International Shakes It, Full Force Fuels It, River City Turbo Spools It, ID Tunes It, and Trucks Unlimited keeps her Rockin the Road with 500+ BADASS Ponies
I would expect the MAP reading to be lower than expected due to less flow.
__________________
The IAT2 will be cooler without a doubt. The MAP may vary slightly but I cant imagine it being enough to throw things off (the map statement is theroy on my part, havent actually logged this) EGR or no EGR, the IAT will still read (change) with boost and engine load as the Turbo will still compress the air charge, causing temp to rise causing IAT2 to sense this.
I completly agree with you on trucks (especially early) with just a delete could be troublesome, especially for people like you and I to diagnose. However with a reputable tuner that knows what he is doing all these paramaters can be acounted for so the PCM can perform as designed.
__________________ God is Great, Beer is good, people are crazy
'06 F250 PSD XLT, CC, SB, 4x4, SCT custom tune from eric, ARP studs, autometer gauges, 4'' MBRP turbo back, AFE stg II, EGR delete, Zoodad, Chrome step bars, '08 mirrors, viper Alarm, Rough Country 8'' Lift, MT MTZ 36-15.50-20, 20X10 Motometals.
So what I am getting out of this is that by cutting out the scoop, capping off the egr feed on the up pipe and the EGR cooler in my 2005 6.0 if I do not have a tuner to adjust for the EGR delete, I will imminently run into problems.
I wasn't aware that it was not a stand alone mod.
Sorry I'm just a grunt and some of this terminology just needs broken down barny style sometimes.
In a nuttshell, yes. Do people do it without a tuner? Sure. Would I? No.
Hey this is somethingI know about!! You are talking about the EPA mode. When PID 0400 is set the PCM limits Boost to reduce NOX.
This "feature" was introduced in the buzz flash. On federal 03 and early 04 a CEL will not be set.
P0400 EGR Flow Failure (outside the minimum or maximum limits) The EEGR system is monitored once per drive cycle during steady state conditions above 48 mph . The test will fail when a malfunction is detected by PCM calculations indicating the EGR flow is less or greater than expected.
EEGR valve stuck open or closed
Connector to EEGR not seated
EEGR motor windings shorted or open circuited
No power to EEGR
Harness open or shorted to power or ground
Vacuum signal to MAP restricted or leaking
MAF sensor signal erroneous
Damaged PCM
Carbon build up in EEGR valve seat area
One or more sensor not responding or out of range
All of the following sensors input data to the PCM for proper operation of the EEGR system: ECT, CPS, IAT, MAF, TP, MAP. Any DTC relating to these sensors must be resolved prior to addressing
__________________
Steve Cox-2003.25 F-250 CC 6.0 FX4 King Ranch
4" Turbo back-Spartan Phalanx- OMG tune
Ranch Hand Cattle Guard-Hollandia sunroof
K40 2000 Radar & Laser 48 Gal fuel tank-Pioneer AVIC-D3,3 amps,12' sub, DVD, TV in headrests JOIN NEW MEXICO CHAPTER HERE!
I would suppose the more skilled tune writers like Eric @ Innovative, Tadd @ Elite, and Matt @ Spartan have all made their EGR-delete programs to take all this into consideration? If so, then that is the route that I will definitely take when I finally do my EGR delete.
Thanks for the great info guys!
__________________
05 F-250 CC/SB FX-4 Silver 6L Powerstroke: Wrangler 275/65R20's, 55W/5000k HID headlights, DieselSite Coolant Filter, Quadzilla Commander, Magnaflow T409SS 3.5"DP/4" w/Cummins Cat, B&M Deep tranny pan, Precision Industries 1600rpm stall Torque Converter, Mag-Hytec Rear Diff Cover, Fumoto valve, HD Bilstein Shocks, ARP Headstuds and no more oil leak.
