Need some advice.
I personally would go with the Ford Racing 4.30 gears then. Better to have a bit too much IMO than not enough.
the Heavy Duty F-150 comes with 4.10 gears from the factory and they are noticeably peppier than a 3.73 F-150.
if 4.30 is too much gear, you can offset that at tire time. A slightly taller tire will kill the deepness of the gear if you need less.
SWMO F-350
03-27-2010 07:46 PM
