cheap spray in bed liner
Old 08-01-2009, 09:29 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Out of all the "do it yourself" ones. Which ones come out best. I used Hurculiner before and i was not pleased. I want to do Line-x but this is not my truck. It is for Josh's 79. It will never haul anything. The Hurculiner was so cheap, i am not using that again! Anyone ever use POR15 bed liner, or any other type
Old 08-01-2009, 10:19 AM
hp246's Avatar
hp246
hp246 is offline
I used Gatorguard from Eastwood. I didn't use it in the normal way though. I used it to line the floor of the cab of the truck pus to protect the underside of my fiberglass fenders. It can be sprayed with a bedliner sprayer or brushed on. I brushed it on. No complaints for what I used if for. So far no chipping. Its been on for about a year, but this isn't an everyday driver.
I've also used some of the aerosol can stuff for touchups (Duplicolor) , and to cover part way up on the sides of the bed to give a two tone look (SEM). No complaints there either but neither is getting any hard use.
Old 08-01-2009, 12:14 PM
hacking_in2002's Avatar
hacking_in2002
hacking_in2002 is offline
I've seen Gatorguard used a couple of times. One was in a King Ranch F-150 and the other in a '79.
They sprayed in well,looked really good, and both of the owners of these trucks said they're holding up really well.
Plan on using it in my own pickup in the next month or so!
Old 08-01-2009, 01:20 PM
Customcab's Avatar
Customcab
Customcab is offline
Spray in bedliner is the way to go; I've never seen a brush / rolled type liner last or look smooth in my opinion.
Speedliner sprayed in my 65 model; waiting for my buddy to reopen his shop and spray my recent 78 F100 I've restored.
Mitch
Old 08-01-2009, 01:47 PM
SeattleWills's Avatar
SeattleWills
SeattleWills is offline
I think most of the do it your self ones will work if you do all the prep correct. I have used the herculiner from Home Depot I think a few years ago with no problems. You just have to sand and sand and clean and clean so that every little spot will stick good to the surface. If the paint/metal is smooth you need to make a good bond for the liner to stick too. Lots of work but it can look nice and last a long time if done correctly, just dont get in a hurry to get it done.
Old 08-01-2009, 02:01 PM
superd02's Avatar
superd02
superd02 is offline
im gonna back up the gator guard as well
we use it at work its easy to use and fair priced
its the best ive used but i will say that if your going to "USE" your truck to throw a rubber mat over it
the second week i had it in my truck i loaded a pallet of block in there and the forklift guy scraped it up pretty bad
however repairing/topcaoting it made it look new again.
Old 08-01-2009, 02:42 PM
Diesel_Brad
I sandblasted a bed and the hurculiner didnt stick. I wouldn't use it again if it was given to me. I used a power washer to strip the liner out.
Old 08-01-2009, 11:17 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Like was said, it's all in the prep.
If all you did was sandblast and then apply the bedliner then no wonder it didn't stick.
The bedliner needs quite a bit of "tooth" to stick, and also you should notice on most of those applications they say to NOT apply to bare metal, but to scuffed paint.
Josh
Old 08-02-2009, 12:36 AM
superd02's Avatar
superd02
superd02 is offline
Josh
there is an acid treatment that we have to put over the scuffed paint when we do bed liners or the company wont warranty their product
Old 08-13-2009, 11:28 PM
bill015's Avatar
bill015
bill015 is offline
I have Qwikliner and it works well. QWIK LINER Spray-On bedliner is industry proven to provide my truck bed with anti skid, permanent abrasion-resistant protection. The unique flexible, textured, non-porous lining is easy to clean and will not warp, crack or peel.
Old 08-13-2009, 11:35 PM
superd02's Avatar
superd02
superd02 is offline
is that what the can says?
Old 08-13-2009, 11:47 PM
70 Bronco TX's Avatar
70 Bronco TX
70 Bronco TX is offline
Too funny!
Old 08-14-2009, 07:04 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,342 Likes on 2,486 Posts
Ck this brand out, have heard pretty good reviews on FTE about it. I am going to give it a try in the cab of ol Red.
http://www.durabakcompany.com/
Old 08-14-2009, 07:15 AM
Diesel_Brad
Josh
I'm sorry, but if freshly sandblasted metal does not give enough "bite" NOTHING will
Old 08-14-2009, 10:32 AM
hacking_in2002
So far the only thing that I have used that calls for sandblasted metal is powdercoating. Everything else requires some specific grit scratch to adhere to. Check this article out http://www.customclassictrucks.com/t...ner/index.html
They say that Line-X shops they spoke with recommended using a die grinder to cut patterns on the surface for adhesion!
Quick Reply: cheap spray in bed liner
