Hydroboost conversion done!
#61
Ahhh... I see said the blind man.
Looks like the Chevy booster I posted has a pushrod as long as the 2001 Superduty.
As for my pedal, I couldn't possibly come up anymore, the brakelight bracket is almost right against the stop. Unless One were to drill a new hole in the pedal for the pushrod bolt.
Josh
Josh
#62
#63
#64
#66
You have to use a P/S pump that is has two returns. One comes back from the P/S box and the other from the hydroboost. If you are getting stuff from a donor truck, it's best to pull everything including the P/S pump. Get the hoses, brackets, and P/S pump. That's what I did when I pulled mine out of an '88 F450. The F-450 M/C is too much and I will be switching back to a '78 F-350 M/C sometime soon. I hear the F-250 M/C works well though.
#67
#69
Still just did not have the right pedal feel, well I got that fixed!I replaced the front two rubber lines and the rear rubber brake line with custom made stainless braided line. huge difference in response and pedal feel! I had all the lines custom made at a local truck service center. The really expensive part was the rear because the hose is part of the line block that bolts to the axle housing. I ended up reusing the stock block but machining and threading it to accept the new line. All in all for 127.00 i'm happy!
#71
#72
#73
The booster bolts to the bracket and the booster pushrod bolts directly the pedal in my application. No rocker bracket or pivot point.
My 68 bronco has a pivot point behind the booster bracket.
#74
#75
I also pulled mine out of an F-450 and it was a direct bolt-in, except that I made brackets to mount the booster to the firewall and had to rebend the lines a bit. I currently have a 351M and the pump bolted right on my current P/S bracket. I don't know anything about the L&L bracket, but I would expect the pump would bolt up fine to it too.
