Installed Transfer Flow replacement tank
I just installed the Transfer Flow replacement tank with the help of my friend this weekend. We had one gas line that was tough to get off but once it came off it all went together very well. Transferflow put the kit together with everything that I needed and provided good instructions. I will do it again when I buy another truck.
It took us about 2.5 hours to install the tank, we had trouble with getting one of the gas lines to come off of the tank and we took our time as we didnt want to break anything. You could use one floor jack, two makes it a little easier, it diffinately takes two people though. Other then that all you need is a socket set.
1) have the tank amost empty
2) remove rear tire on drivers side
3) remove skid plate
4) put jacks under tank and remove support straps
5) lower tank, disconnect power, and (2) gas lines, and (2) vent lines, fill tube, and vent tube
6) install sending unit on new tank after bending float for deeper tank (they provide a full size picture to make sure you bend it correctly)
7) raise tank and connect all gas lines and vents
8) tighten straps provided and fill with diesel
It didnt need to take as long as we did but since neither one of use had done anything like this before we read everything over and over to make sure we didnt miss anything, we also installed the rear air bags at the same time.
Leon
Leon
Originally Posted by jrc55
How much lower does it hang below the frame than the stock tank?
Thanks, Joe.
Thanks, Joe.
Leon
Originally Posted by mikey2000
How do the fuel gauge and the message center function now? Did you get a lot more miles to empty?
Leon
Thanks for the great write up!
Transfer Flow's facility is only a few hours from me so I plan to go there to a in the bed tank installed. I was hoping to get a tank that I could transfer fuel from, to tractors and such, while still being plumbed into my main tank, however they don't make such an animal.
I've been told to get the transfer/refueling tank first then get it plumbed into my existing tank by another vendor.
