What mods would you do while your Excursion's Body is lifted off the frame?
#31
#33
thanks all for the compliments!
Heres some more of what happened when the body was removed and susequently re-installed.
If anyone has any questions on how these trucks are put together, I probably have the answer! I have had almost everything apart except for the drivetrain. It has been an incredible process.
One thing is for sure, I know everything about my truck... intimately!
Installed a wicked wheel and a 1.0 A/R housing
Installed RiffRaff FRX
1.0 A/R turbo housiung and Bellowed up-pipes installed. Also you can see the 4" SS down pipe from the Magnaflow exhaust I installed as well. I also deleted the EBPV and the AIH. (this was all so easy with the body off!!!)
Engine together before putting the body on...
Body being lowered into place. (this was a 2000 EX body form a V-8 Gas 2WD). I ran into many wiring issuse between the two model-years. uuuugh...
ALL THE WAY DOWN ON THE MOUNTS...
Checking clearance at the turbo wastegate actuator. I used the clip from the EBPV instead of the tiny circlip. The 1.0 housing had a bigger pin and the EBPV clip worked perfectly.
rolled off the lift (not driveable yet). Miles of wires & hoses to connect up at this point...
More later on the interior work and the suspension lift...
#35
FIRST UP ON THE INTERIOR: I added mounting holes/nuts for the 2nd row bucket seats. This body was from a 2000 m/y so the buckets were not available then and therfore no mounting holes. My 2002 diesel Limited interior had buckets that I planned on using.
More on this issue here: https://www.ford-trucks.com/forums/8...l-it-work.html
pics just show the holes being marked. I then drilled holes and welded nuts underneath. (actually did this before this body came off of the 2000 2wd chassis.
#38
#39
RacinNdrummin
375
12-29-2018 05:13 PM
stock351W
31
03-01-2010 08:55 PM
