Turbo pedestal leak
Turbo pedestal leak
My 99 PSD is leaking oil again. I believe that it is coming from the turbo pedestal o-rings AGAIN. Ford fixed this a couple of times under warranty and now it is leaking again. This truck only has 53,000 miles on it. It has only been driven about 7,000 miles since the last time that Ford fixed it.
I am going to fix this myself this time. I have put the Banks turbo housing and wheel (we all make mistakes) on this truck when it was new so I know how to get it apart and back together.
Is there anything that I should look for when I have this apart to maybe find out why it keeps leaking?????????
Are there any other parts that I should change to keep this from happening again?
Is the Banks wheel comparable to the "wicked wheel"? I still get some turbo surge at higher boost (26 lb) when pulling a heavy load.
Thanks, Kevin
Thanks, Kevin
How bad is your leak? Does it start small and grow over time? Maybe they're just not tightening the turbo bolts tight enough. I've read where some guys developed leaks following the factory torque specs and needed to tighten it up just a hair more.
The banks wheel is the same as the wicked wheel (except for the price I'm sure)
When you get in there and take off the turbo, you'll see the top o-rings, I cleaned up all around the o-ring area, used a light scouring pad on the bottom too, cleaned it up good also, bottom view.. Get a turbo reinstall o-ring kit from Guzzle http://dieselorings.com/ , their very good o-rings, made of Viton, good for bio blend fuels and low ULSD diesel..
Thanks, Kevin
Thanks, Kevin
Like Chris said. Recheck the torque on the bolts I had the same problem one time I torqued them back down and all was good again. If you take the turbo/pedestal back off get new o-rings and use the blue locktite on the bolts when you go back together. That will fix that part but while your there check the evbp rod they will leak also.
Don't forget to check the EBPV plunger assembly.
When we did my 38R install, my small oil leak (at the time, I had no idea what the source was) became a really big oil leak, but all the O-rings on the pedestal were sealing fine.
It turns out my plunger was the source, and it became a huge leak when we had the pedestal off and took the plunger out to clean it up.
I was lucky, Pete swapped in a van turbo which doesn't have an EBPV, so he gave me his and it solved my problem.
Start your engine and grab a flashlight. You should be able to see any oil coming from the stem of the plunger if it's leaking there.
Stewart
Stewart
Is the Banks housing a compressor or exhaust housing? If it's a ported compressor housing, AND you have the Banks/Wicked Wheel (yes, they're the same), you shouldn't have any surge!
I am not familiar with the EBPV plunger. What is it and where is it? It has been 10 years since I had that apart.
Kevin
It's my understanding that the O-rings are usually the cause of pedestal oil leaks, but in my case the O-rings were fine (just replaced) and it was my EBPV plunger that wasn't sealing against the cylinder walls properly.
With your engine running, you can see with a flashlight if the oil is coming from that spot.
Stewart
I had the same problem the ebv is what the problem will be and your best bet would be to eliminate it is to remove the ebv plunger there are instructions on the net how to do it doesnt take that long i tried replacing my pedistal twice it lasts for a while then it goes to **** so i blocked it off and it works fine now
