Question on lifts and ujoints
Old 06-08-2014, 07:56 AM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
I have a 4 inch lift on my 75 f250 4x4,Im replacing all yokes with 1350,,,axle and t/c.With going 4inch will I be ok with running single ujoints?
Old 06-09-2014, 02:43 PM
teds74ford's Avatar
teds74ford
teds74ford is online now
I ran single joints on my old truck for years. I changed them during the rebuild and never after that until I sold it. 7 years or so on the same joints. May be still in the truck...
Old 06-09-2014, 07:42 PM
co425's Avatar
co425
co425 is offline
Just for a measure of longevity and a smoother driveshaft. I'd think about going to cv shafts, especially since it sounds like you'll be having new shafts made anyways. I know my driveshafts were shot, but the vibration difference was substantial.
Old 06-09-2014, 08:50 PM
lafermedavid
ujoints
That would be the rear output shaft,and front output,small drive shaft,single joint?Ted what was your lift?
Old 06-12-2014, 05:15 AM
teds74ford's Avatar
teds74ford
It was about 4" over stock, or, since mine was a 2wd conversion, about 7" taller than 2wd
Old 06-12-2014, 06:18 AM
lafermedavid
Thanks Ted/Thanks co425
Old 06-12-2014, 10:55 AM
lafermedavid
DS
your small drive shaft; are you using cv as well?
Old 06-14-2014, 08:20 AM
teds74ford's Avatar
teds74ford
I dont have the truck anymore, but it only had 2 shafts. I used a married case for the conversion. Both the front and rear shafts were plain u joint style shafts. I did build a small carrier bearing spacer if I remember correctly
Old 06-14-2014, 08:38 AM
lafermedavid
drive shafts and ujoints
Yes,Ill be replacing drive shafts,probably safe bet to go with the cv,,,just not sure whether,Ill need a cv with short drive shaft on the divorce t/c.thanks folks
Old 06-14-2014, 09:37 AM
co425's Avatar
co425
co425 is offline
No your intermediate shaft can be a regular shaft. However I would definitely go the 1350 route.
zman7125
08-07-2014 12:22 PM
nelly781
1978 - 1996 Big Bronco
03-26-2006 09:33 PM
onirot
11-29-2005 02:42 PM
Matt68RR
08-02-2005 08:26 PM
Pastmaster
01-19-2002 06:11 PM
Quick Reply: Question on lifts and ujoints
