89' f150 302 comp ratio?
Thought id just post this.
I dont believe the factory comp ratio on a 89 F150 is anywhere near 9:1
I pulled my engine down for a rebuild. We decided to do do a few things while its apart.
Over size stainless valves
Porting.......jeeze some serious work work was needed here!
Forged pistons..... just for the hell of it. Had some laying arond the shop so we threw em in. We run a machine shop/ engine re conditioners over here in Oz
Mild cam... Didnt want to go too nuts here as its still a factory ECU (MAP based)
Anyhow i wanted to up the comp ratio a decent wack so we took 10 thou off of the block and 30 thou off of the heads.
I cc'd the heads and came up with a comp ratio of 9.1:1.
So the factory 302 ratio would have to be very low to start with. Im guessing around high 7's low eights.
For what its worth the pistons we put in were pretty similar in dish / valve relief size to the factory ones we removed.
on
1 Post
yes, the factory hard ratio (meaning the total volume-swept volume/total volume) is 9.1 (ford says 9.2:1)
the 351 is 8.8:1
at 100% VE you will get the stated CR if you took the time to measure it.
If you did not bore/stroke the 302 the its 4" bore by 3" stroke. the E7 heads pipe in around 62cc (YMMV)
you can look up the compressed thickness of the factory head gasket.
lastly take into account any piston dish or height above/below deck at TDC.
it aint anywhere near 7-8:1
and please dont use a compression gauge to guess at CR - but if you had to, 120psi is 8.2:1 (which means 9.2:1 overall cuz at 1:1 the gauge would read zero since 14.7psi msl is the baseline)
the 351 is 8.8:1
theblueford
06-07-2017 11:52 AM
steverinaz
02-06-2017 08:27 AM
Scott Glenn
11-22-2016 03:24 PM
