'94 Auto Gear Selector Lever Suddenly Loose
Old 07-27-2009, 04:37 PM
'94Mesquite's Avatar
'94Mesquite
'94Mesquite is offline
I have a '94 F150 4X4 351 w/auto transmission. Yesterday when I went to shift it into Reverse to back out of my driveway there was no response from the transmission. I fiddled with the gear shift lever and pulled it down to where it indicated Neutral, it then shifted into reverse. I experimented with the shift lever some more and noticed that the lever seems to feel loose. In order to get it to shift into the gear I want, I have to go to the next gear down before the transmission will engage. At that point the lever can be pushed back up so the indicator points at the gear I am in (without having to pull it forward). Where should I start to find the problem?
Old 07-27-2009, 10:52 PM
stuart1's Avatar
stuart1
stuart1 is offline
Look under the dash just above the steering column.
There are 2 bolts that work loose or the shaft is cracked.
Old 07-29-2009, 10:36 AM
'94Mesquite
Exactly right Stuart.
The problem got even worse yesterday when the transmission would not go into Park.
I found one bolt rolling around on the floor and it was the culprit. I re-installed it and everything is alligned and working properly now. Thanks for the help.
Old 07-29-2009, 02:56 PM
stuart1's Avatar
stuart1
stuart1 is offline
You are more than welcome.
You gotta get lucky once in awhile, even if it is repairing a vehicle.
zalinth
11-01-2016 04:58 PM
mudram99
1997 - 2003 F150
21
01-22-2016 03:41 PM
HunterSThompson
07-05-2015 05:11 PM
DaveMac2Vans
Aerostar
05-15-2006 09:36 PM
PatL
11-13-2001 05:21 PM
Quick Reply: '94 Auto Gear Selector Lever Suddenly Loose
