Looking for a good electrical guide book.
Well, I really don't use a book for wiring - per se. I've just been making all this stuff up and you guys believe it.
If a question comes up on a particular stock signal flow I will try to get ahold of a stock wiring diagram.
Outside of that, I guess I just rely on my own experience. Electricity is very simple (I know I keep saying that and you guys think I'm nuts) but it's just like plumbing - connecting the dots. It's funny but it's confusing until; one day it clicks then it all makes sense.
I might venture to say that we probably have one of the best documented specialized electrical librarys right here on FTE. I can't think of anything that hasn't been duscussed.
But also, I have found that the older books - like those written pre 1940 - the hard cover kind you find at swap meets and garage sales, are the easiest to understand because they are so fundamental. There wasn't too much in the way of electrical complexity then.
And also, as much as I hate to say this, technical publications were very much better written back then as well.
I know that doesn't help much. If you have a specific goal in mind - lets say to rewire your truck. I would start with a good diagram. It doesn't have to be stock, it's more important that it is simple, readable, and has the features on it you want. Build your own if you like - I did. If there are things you want to add, you can find them on different diagram transplant it to yours. When you have everything you want. Remember it looks like spaghetti both in the truck and on the drawing, but everything is powered by one wire that starts someplace and ends up someplace - it's that simple - one wire at a time.
For our trucks, I have some good generic diagrams that you could wire any truck to, and individual pictures of component wiring. Take a look in my #4 gallery. I have these on Power Point and am always willing to send them to folks. With the Power Point versions, you can enlarge them, but more important, you can modify them - change things for what You want.
And of course you can write anytime!
I know that didn't answer your question very well, but I hope it helps some!
Thanks for your thoughts. Julie your forgetting that your experience allows you to "just do it". I agree that a diagram is a basic requirement but the problem comes when you make changes or upgrade to what is printed. I am not savy about electricity. Stuff like wire sizes, best connection methods (solder or not), best location for components and junction blocks, using relays. I am good to go on 6 to 12 volt alternator conversion thanks to you and others here. My 54 with the 223 six came in pieces so basiclly I'm starting from scratch. Hope you all are here for the long haul. Im going to need you!
Bob
Bob
It all depends on whether you are looking for a "cookbook" or a book on electrical theory. It sounds like you want a little of both. Most folks can grasp the idea of hydromechanics (how fluids work) much better than electricity...that said, I try to explain electrical priniciples in term of water and pipes. Water pressure in a pipe is like voltage and water flow (volume) is like current. If you have a garden hose and you compress a section of the hose while water is flowing through it then the flow is restricted...this is the same as resistance in an electrical circuit.
I would suggest that you gain a basic understanding of Ohm's Law (E=IR) and then delve into the automotive-specific literature. One last thought...you can never have a wire that is too thick, if you have a question about using 18 ga or 16 ga always go with the heavier gauge. Good luck...
Bob
Bob
As far as finding a good drawing then making changes goes, that's why I drew out my own in Power Point - so I could change them at will. I started with the drawings from the 51, then added things like one wire alternator, fuses etc. So it's a custom drawing. Like I said - just connecting the dots.
I would be tempted to get one of the books the guys have listed above, but maybe also take a class in electricity at the local Community College. It won't matter too much if it's car or house, etc, the theory is all the same, and it sounds like that is something you are looking for - the basics. You can also learn quite a bit just by reading through the electrical and troubleshooting sections of the Shop Manuals.
