Mobil1 ATF?
Mobil1 ATF?
[updated:LAST EDITED ON 31-Dec-02 AT 01:18 AM (EST)]
Mikemc - I don't see how you could lose on this one.
No, I have not tried M1 ATF in a manual, however ...
in spite of the "spirited" debate(s) on synthetic "motor"-oil, I can't recall many (rather any) on synth. trans fluids.
I believe it is agreed, even among "dino" "loyalists" that synth (oils/fluids) have (at least, MAYBE at most) superior cold temp. properties, in addition to extended interval capabilities. Being a sorta' "Low-Tech" kinda' guy, I can't, maybe choose not to, get into all the technical data stuff (well anyway it's late and I'm tired - sorry).
I'm guessing you have somewhere around, what, 15-20 thousand miles service on your trans and a change-out, of any type that meets specs wouldn't hurt (though, I am thinking automatic now - I believe a manual has a longer interval), though still, an early 1st change could only be a good thing, right? Especially since tranny intervals ARE longer (I've NEVER known anyone to change more often than once-a-year/every 15,000 miles - though I'm sure Pro-Racers do!).
If you are going to change anyway, and your manual calls for Mercon ATF, M1 certainly meets (or does it exceed?) that spec. - why not.
I truly believe you'll find a difference (if only slight) w/ a synth. on cold shifting. If not, and you were going to change anyway what have you lost - certainly not anything worse for wear.
If you can afford any price differential - I say "thumbs-UP"!
Sounds like a "win-win" scenario to me.
Let us know - and/or at least you have one "opinion"!
Best, Glenn . . .
Best, Glenn . . .
Mobil1 ATF?
I searched websites and found the following viscosity information:
Mobil 1 synthetic ATF
viscosity at 100 degress C - 7.6 cST
viscosity at 40 degress C - 35 cP
viscosity at -20 degress C - 850 cP
viscosity at -40 degress C - 6200 cP
Amsoil synthetic ATF
viscosity at 100 degress C - 7.5 cST
viscosity at 40 degress C - 36 cP
viscosity at -20 degress C - 1030 cP
viscosity at -40 degress C - 7150 cP
Redline synthetic ATF
viscosity at 100 degress C - 7.2 cST
viscosity at 40 degress C - 32.5 cP
viscosity at -40 degress C - 4500 cP
Valvoline dino ATF
viscosity at 100 degress C - 7.7 cST
viscosity at 40 degress C - 36.1 cP
viscosity at -20 degress C - 1300 cP
viscosity at -40 degress C - 17,500 cP
You have to start getting prety cold to see a significant viscosity difference, but dino is thicker in the cold.
I decided to go with Mobil 1 because I tow, and i think that synthetics will take the heat better without cooking.
Valvoline dino ATF
Mobil1 ATF?
[updated:LAST EDITED ON 31-Dec-02 AT 10:21 AM (EST)]I have personal experience with this and I can honestly tell you that changing to M1 ATF in your 2002 tranny WILL NOT change your shifting on cold mornings. I have tried several different syn ATF fluids in my manual and nothing helps. In my opinion I believe MERCON ATF shifts better then the others. I am currently using REDLINE D4 ATF and I still believe MERCON ATF shifts better then that.
>My 2002 Ranger with 3.0/5 sp.manual is just a tad tough to
>shift on cold mornings. Has anyone tried M1 ATF in a manual?
>Could you tell a difference? My tranny calls for Mercon ATF
>and the M1 meets this spec.
Mobil1 ATF?
[updated:LAST EDITED ON 31-Dec-02 AT 06:49 PM (EST)]>I have personal experience with this and I can honestly tell
Greenpus - greatly appreciate & respect your experience, and 'honesty', well that's a virtue!
I'll consider myself enlightened (& thanks to jschira as well!) - it's actually good (GREAT!) to know "plain-vanilla" (& less $$ !) Mercon is doing as well, in fact it sounds like a better job, than the GREAT "straight" (mighty?!?) synth.
Two questions -
1. Are we talking Motorcraft Mercon, or another brand (?)
And-ah 2., how "cold" are we talkin' - where do you "shift" (live/drive), and/or what do the ambient or average "cold" temps run where you're speakin' from - just curious (hungry for education), not lookin' to scrap!
Regards - Glenn . . .
Two questions -
Mobil1 ATF?
<<<And-ah 2., how "cold" are we talkin' - where do you "shift" (live/drive), and/or what do the ambient or average "cold" temps run where you're speakin' from - just curious (hungry for education), not lookin' to scrap!>>> I live in KY and we have had several mornings in the teens this winter. BTW the truck has a little over 11K miles so it should be considered broken in.
Mobil1 ATF?
i just put M1 in my 99 4.2 tranny and it definitely feels a bit more slick shifting in tucson, az. (in a colder clime you'd probably notice more difference.) HOWEVER, the old oil was overdue for changing, so maybe the syn shouldn't get all the credit for the improvement i noticed.
