leaf spring bracket rusted out
Old 07-19-2009, 06:21 PM
twags6's Avatar
twags6
twags6 is offline
Hey guys. My dad's truck was riding rough lately and after checking it out, we found that the rear brackets (one the shackle is attached to) for the rear axle are rusted out. The right side is so bad that the shackle was up against the bed! How much hassle will it be to replace these? Are we looking at a day job or a few days? I have a torch, so burning the rivets off is no problem, I'm just not sure where to get the brackets. Its a 97 F250-HD extended cab short bed. Its up on jack stands now, but I'll try to get a picture with my cell.
Thanks, Trevor
Old 07-19-2009, 06:50 PM
twags6's Avatar
twags6
twags6 is offline
passenger side mount
Old 07-19-2009, 07:21 PM
79_250RangerLariat's Avatar
79_250RangerLariat
79_250RangerLariat is offline
It's not a bad job to do, If you've never done one before probably a sat afternoon. I've always gotten mine from ford, weren't too badly priced IIRC
Old 07-19-2009, 07:39 PM
RubberDuck's Avatar
RubberDuck
RubberDuck is offline
LMC truck has them too.
Old 07-19-2009, 07:55 PM
twags6's Avatar
twags6
twags6 is offline
I'll give ford a call tomorrow, check with Ed, and look at LMC. Am I correct thinking that they get bolted back on with grade 8 bolts?
Old 07-19-2009, 08:03 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Yep grade 8 bolts. It can be tricky to reach behind the rear fuel tank but it can be done to get the bolts back in
Old 07-19-2009, 08:40 PM
Epd444's Avatar
Epd444
Epd444 is offline
I've never done one on my 350 but I did one on my friends ranger for him.
It wasn't too bad of a job, took me a little time but all in all it was pretty straight forward
Old 07-19-2009, 09:02 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Might want to grind those rivet heads rather than torch them. At the least use blue Loc-tight on those bolts. My two pennies.
Old 07-19-2009, 09:49 PM
scatgo's Avatar
scatgo
scatgo is offline
X2 torch by fule tank =
Old 07-19-2009, 10:02 PM
JethroF250's Avatar
JethroF250
JethroF250 is offline
lmc truck. lots cheaper. i just did mine a month ago with their shackle. im pleased. my other side is due soon to
Old 07-19-2009, 10:05 PM
scatgo's Avatar
scatgo
scatgo is offline
WHY CANT I FIND THE FRONT MOUNT!!!!!!!!!!!! That would be the back mount for the front leaf spring. Please help Many reps to those who can help.
Old 07-19-2009, 10:06 PM
Epd444's Avatar
Epd444
Epd444 is offline
Thats what i did on my friends ranger. Grinded the rivet heads off then used an air hammer/chizzle to get the part out of the frame
Old 07-19-2009, 10:10 PM
twags6's Avatar
twags6
twags6 is offline
Cheaper?!?! They want 370 for the front and 200 for the rear bracket! I hope I'm looking at the wrong part.
EDIT: FTE parts guy has them for 260 front bracket and 141 rear bracket. Wow...
Old 07-19-2009, 10:17 PM
JethroF250's Avatar
JethroF250
45-1373 lmc part number. 49.95 plus shipping
Old 07-19-2009, 10:21 PM
JethroF250's Avatar
JethroF250
front- 45-1379-59.95 45-1404-54.95
Quick Reply: leaf spring bracket rusted out
