2003 5.4 tune up
2003 5.4 tune up
2003 Expy 5.4 w/160,000 miles runs well. I have owned for past 20,000. I want to do a tune up on it, what all should be done? I am thinking: New spark plugs, new fuel injectors...what else? I pull a 7,000lbs. 27ft. travel trailer with it and it only gets about 6mpg, is this normal? Going to be making a long pull to Orlando from Atlanta in September want everything to be A+.
1 - Plugs
2 - Coils
3 - Injectors
I just did all 3 and (getting parts from random ebay sources) kept cost under $200. They kinda all need to be done at the same time.
Also, get some throttle body cleaner, take the TB off and clean it really well. Mine was gummed up something fierce and would whistle at idle, cleaned it, all better.
you might also need to clean or replace the exhuast gas recirculating valve (Autozone or ebay again)
Here's the plug / injector writeup.
https://www.ford-trucks.com/forums/1...ark-plugs.html
2 - Coils
3 - Injectors
1 - Plugs
2 - Coils
3 - Injectors
2 - Coils
3 - Injectors
Can you post some links to these sellers, if you are happy with results.
Thanks for the help.
