Trans service, just thought I'd share!!
Well, I just did a trans service on my 97 with the 4r70w. I hadn't done a service in around 35K which is longer than I like to go. I drained the torque conv. and dropped the pan and put a new filter in. I was able to get about 12.5 quarts of new fluid in it. The pan looked very clean with only a little "dust" on the magnet. There were no visible chunks in the filter. My last service, I used the supertech wal mart stuff and did the same this time. The old fluid had just started to look a little orange so not to bad. I am VERY happy considering the trans has 157K miles on it and still works very will.
JL
I'm guessing the synthetic is going to cost more, but would also be more resistant to high heat situations and stuff like that.
George
your 97 probabaly came with MERCON from the factory. a couple years ago Ford said there going to discontinue MERCON and recommended upgrading all older vehicles to MERCON V when doing service. MERCON is a high quality oil, MERCON V is an upgrade from that. On the question of synthetic, i was under the opinion that V was synthetic oil and MERCON and DEXTRON were not. Im not sure a trans oil that "meets all specs" for MERCON, Dextron and V is porperly labeled if it is not a synthetic oil. THats probalby what Bear was refering to. I dont use "one size fits all" oils. I think it should be MERCON V labeled, which i think is synthetic. IT can be made by a generic manufacturer ---in my opinion.
https://www.ford-trucks.com/tsb/full...hp?tsb=06-14-4
JL
Mercon V is not necessarily syn or even a blend...
Here is the Motorcraft transmission fluid page. They have regular Mercon V, which is not at all synthetic, and Mercon V synthetic blend:
http://www.fcsdchemicalsandlubricant...ssion%20Fluid]
As I said, there have been previous threads where this has been discussed ad nauseum. There are full syn and syn blend Mercon V fluids made by other mfrs, but Mercon V does not have to be synthetic and does not have to be a syn blend.
George
George
