Whats the big problem with a 6.0 powerstroke
We are a public school district, the 6.0 is in a E-450 cutaway van chassis with a 30 passenger school bus body. As a public school district we are tax exempt and can legally either use dyed non taxed fuel or use taxed fuel and file forms to get the tax money rebated to us.
And to clarify our dyed fuel is ULSD. The dye only tells you that it is for tax exempt use. The DNR does not care but the IRS is very interested.
I just bought a 2007 extendedcab F250 4x4 Lariat. It has only 6700 miles on it. Everyone I have spoken to says I will not be happy with the 6.0 powerstroke motor. I think I got a real deal on this truck. It is fully loaded. I plan on pulling a 27' camper plus my 19' bass boat with this truck. Weight of boat and camper together is around 12,000 lbs. Should this weight be a problem ? Any information on the 6.0 would be appreciated.
My 6.0 has been great - I've had it tinkered with for longevity, but that's because I wanted to soup it up. Runs very well.
Did you get it at Courtesy Ford in Conyers? What have you heard about their service dept., in case you need it?
I can't add much to what others have said except to mention that a 4" turboback exhaust and the coolant filter are great ideas. Unfortunately you could get some hassle from the service dept if you take it in for warranty work with these upgrades.
on
I agree about the internet statement. I owned a 07 6.0 ex cab short bed and if it would have been a crew cab long bed I would still have it. I loved it and I never had any trouble out of it. The main thing on the 6.0 is stay on top of all maitenance, use only motorcraft or racor filters and work it regularly if posible. You have a very fine truck take care of it and enjoy it.
To me the best tip I can give is stay on top of the maintenace, religiously, use only OEM filters and the proper oils. Use only Mercon SP in the tranny and personal rec. stay away from tuners. Install a coolant filter if it doesn't have one. Follow the tip I gave you and you should have one dyn-o-mite truck. I have been totally happy with mine and my tow is 11k dry. Take it from there.
6.0 powerstroke
Be sure to read the tech-folder at the begining of the forum, it has a crap ton of info on what to do and what not to do.
https://www.ford-trucks.com/forums/3...ch-folder.html
Don't let it scare you though these are great trucks /engines.
As is has been stated before use OEM parts, keep up on the maintenance and just drive it!
Problems with a 6.0? I took over ownership of a 6.0 van with over 777,000 on it. The coolant system was messed up because the previous owner did not do any maintenance. However, it was running great! I liked the van so much that I upgraded the transmission pan to the larger size with a real filter. Nice upgrade for about $200. I bought a Scan Gauge and noticed my FICM voltage was low. The battery cable was broke. I had Ed from FICM repair rebuilt the FICM.
The EGR cooler was leaking slightly and I paid a Ford MasterTech to replace the oil cooler, EGR cooler, and the HPOP. He did a few other things since he had everything removed. I spent about $3k to prevent any major hiccups. He rebuilt the turbo because I kept on getting the dreaded P0299 code.
The van now has 792500 miles on it and we just completed an 8,000 mile cross country trip. Next year, plan to take the van to Alaska. The 6.0 is an amazing engine. The Torque Shift transmission is beautiful. Sure, it needs maintenance like any other vehicle. The trick is solid preventive maintenance.
My buddy just bought a beautiful 7.3 van with a125,000 on the clock because one of his 7.3 vans blew a head gasket and the other 7.3 van fried a transmission. He killed two 7.3 vans within 2 months of each other. He expects his new van to last up to 180,000 before he has to replace the transmission again.
My point is any vehicle will fail without regular maintenance. He believed both 7.3s would run without regular maintenance. I flushed the tranny on his van and thought I disconnected the wrong line because the red tranny fluid was dark black!
c1goncalves
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
03-26-2017 04:38 PM
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
07-12-2016 11:45 AM
