Camper Shell 3rd Brake Light hook-up? / VA Lifting Laws
Old 07-05-2009, 07:33 AM
Built_Ford_Tough_757's Avatar
Built_Ford_Tough_757 is offline
Hi, I just got a free camper shell yesturday from a friend's dad. He sold the truck it came with a year ago and had no use for it. score . Anyways, it has a 3rd brake light and I was wondering how I should hook it up? I was thinking if I hook it up to the tail lights, the it would blink and make that flash with the turn signals, and hooking both sides would make them stay on when one side should be blinking right? So is there a place in the cab where i can hook up the light? Thanks.
And also, I was wondering if anyone knew if its legal to install two lift blocks on the back axle? I don't think a six inch will match the same as the front now.... And it looks dumb now. Thanks again
Old 07-05-2009, 08:02 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Stacking lift blocks is a bad idea!
If you tap into one of the brake lights to make the third brake light work, then when that turn signal is on the 3rd brake light will flash. Your are right. So, You should be able to hook it to both and have it stay on when either side is flashing. That should be fine.
ctubutis's Avatar
ctubutis
ctubutis is offline
The only way I know to do the brake light thing would be to run a wire off of the brake
light switch under the dash.
Old 07-05-2009, 09:58 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
They make a converter for that exact purpose, they can be had at a trailer/towing shop.
It takes feed from both the tailight wires and produces a single wire for the third light (or trailer lights).
They come in universal that gets spliced in or vehicle specific that that plugs in.
-Enjoy
fh <font color="#FF0000">:</font> )_~
Old 07-05-2009, 11:12 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
That will not work. It will tye the left and right circuits together and have all the lights blink together
Old 07-05-2009, 11:52 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Technically if you read the law, no suspension modifications are allowed in Va. But, the general rule I have found that most cops and inspection stations follow are; blocks are allowed in the rear, but not in the front. The 4x4 trucks actually had a block from the factory in the back, and you will find most trucks with lift kits have the lift kit block installed on top of the factory block with longer u-bolts.
Old 07-05-2009, 02:27 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
-Enjoy
fh : )_~
You could take a feed from each brake light and run it through a diode. The diode will prevent/block back feeding to other bulbs. The stripe on the diode goes toward the new 3<SUP>rd</SUP> brake light.
Old 07-05-2009, 05:50 PM
Festus Hagen
Methanoholic
Hmmm, Never thought of that, I'll have to give it a shake down look see!
Thanks JimsRebel
-Enjoy
Old 07-05-2009, 11:12 PM
Thanks everyone for the help.
Old 07-06-2009, 06:48 AM
TexasGuy001
A guy I know made his work by doing something like that. He didn't buy any adapters or anything. Maybe he did something else.
Old 07-06-2009, 04:11 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
You would need TWO diodes but this would work great.
Wire from left turn and brake lamp, through First diode -->, to 3rd brakelamp.
Wire from Right turn and brake lamp, through Second diode -->, to 3rd brakelamp.
Splice the two taillamp wires together at the 3rd brakelamp, after the diodes.
BTW, this would also work for retrofitting and replacing a 1980-1992 Cargo lamp, with a 1993/1996/7 combination third brake and cargo lamp assymbly.
Baatzy
01-14-2016 10:57 AM
laciclemens
1997 - 2003 F150
04-05-2011 02:47 PM
txjason1
06-16-2009 03:56 PM
07F150trucknut
Electrical Systems/Wiring
01-19-2008 03:56 PM
Cowboy Tom
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-28-2005 02:27 PM
Quick Reply: Camper Shell 3rd Brake Light hook-up? / VA Lifting Laws
