Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 02:36 PM
drof46's Avatar
drof46 drof46 is offline
drof46 is starting off with a positive reputation.
1973-1977 steering column wiring diagram???
Anyone with a 1973-1977 steering column wiring diagram. If possible could you scan the wiring diagram for this section and e-mail or PM it to me. Trying to wire up one in my 1966 and trial and error takes me forever.
haus_von_stein@yahoo.com
Thanks,
Ben
__________________
1966 F-100 Custom Cab (work in progress)
351 Cleveland 4V (DOAE-J) *No its not a 351M**
C4 trans, 4.11 trac loc
Ground up resto. Ground is done, ran out of money for the up.
  #2 (permalink)
Old 07-04-2009, 08:50 AM
drof46's Avatar
anyone?
Thanks in advance
__________________
  #3 (permalink)
Old 07-04-2009, 07:49 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
This one?
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #4 (permalink)
Old 07-05-2009, 09:32 AM
drof46's Avatar
Thanks, thats a great start. The 73 is going into a 66. Can anyone identify what the wires go to? Example: LT Green = left turn. I'm replacing my wiring harness with a kit from EZ wire.
Thanks
__________________
  #5 (permalink)
Old 07-06-2009, 08:44 AM
drof46's Avatar
To the top.
__________________
  #6 (permalink)
Old 07-06-2009, 12:53 PM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
Sorry I can't help but when you finish this project could you write a comment or two as to your thoughts and/or tips on the wiring harness? I'm looking to re-wire my 77 with an ez wiring kit.
__________________
2001 F-250 7.3L Ext. Cab, SB 4X4, MBRP 4in, DIY intake, autometer pillar gauges, DP F5 tuner (40,80 and 120), ride-rite air springs, 08 Diff. cover.
1977 F-250 5.9L Cummins Nv4500 (Work in progress)
  #7 (permalink)
Old 07-06-2009, 03:50 PM
The years may vary...but do look for a wiring manual. I only have the '79.
__________________
Chad
  #8 (permalink)
Old 07-06-2009, 08:51 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
I do have the Factory diagrams from 1973-1988.
They are very large, and difficult to scan. Will see what I can do.
  #9 (permalink)
Old 07-06-2009, 11:21 PM
1981 Ford F-150
Here you go...
be warned it's large...
http://i447.photobucket.com/albums/q...scan0002-1.jpg
  #10 (permalink)
Old 07-12-2009, 11:38 PM
drof46's Avatar
Thanks so much. Been working on getting the 66 bed to fit the 79 frame the past few days.
As for the EZ wire kit. Its really straight forward. Each wire is marked telling you what it is. I am doing a total rebuild so I went with a 1 wire alternator which eliminated a few wires along with some ugly boxes(regulator) under the hood. Also installed a HEI distributor which eliminated a separate coil or brain(duraspark) and the associated wires. Tips? Really just follow the book. I sat in my living room a couple of evenings and laid out the different sections. Front lights, engine section, tail section, guages, everything else. I also installed new digital guages from dakota digital so I did not have to worry about wiring into the existing guages. Dakota comes with a brain and everything is marked very well. Also was able to eliminate the wire speedometer cable because the kit comes with an electronic speedometer. I am definately not an electrical guy but the kit is worth it. After pulling things out I found numerous wires that had partially melted over the years. Not a very safe situation in my opinion. Of course my wires were 11 years older than yours.
__________________
  #11 (permalink)
Old 07-18-2009, 02:19 PM
I'm sure my wiring harness has safety issues. There is a bundle of wires under the box that are wire nutted together from a previous owner. Did you like the quality of the wiring harness? Any issues with cheap parts that you noticed?
__________________
Tags
1978 , 1991 , 2004 , 77 , column , custom , diagram , f150 , f250 , f350 , ford , gm , pickup , steering , wiring , xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
