Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2009, 01:42 PM
rich gill's Avatar
rich gill rich gill is offline
rich gill is starting off with a positive reputation.
where did u mount your DP tuner switch?
My DP tuner is on the way
I found several threads but none of them show our years.
Anyone have any pics?
Thanks
Rich
  #2 (permalink)
Old 07-03-2009, 09:14 PM
2 stroke man's Avatar
2 stroke man 2 stroke man is offline
2 stroke man is starting off with a positive reputation.
i mounted my TW on my pillar pod. i don't imagine it would be much different.
the matal is a piece of metal off my truck that i think i cut out of the bed when my ball hitch was installed.
__________________
GOT MY CAT!
2002 Powerstroke 7.3
1997 Powerstroke 7.3
1990 F700 Dump truck ford 6.6 diesel with garret turbo
  #3 (permalink)
Old 07-03-2009, 09:15 PM
i have yet to glue a bezel around it obviously
__________________
GOT MY CAT!
  #4 (permalink)
Old 07-03-2009, 10:20 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
I installed mine in the driver's door arm rest. I like it, it's convenient but I would have to think long and hard before I did it again as it is a Royal Pain in the A$$ to thread that cable through all of the nooks and crannies that it must go.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #5 (permalink)
Old 07-07-2009, 09:41 PM
rich gill's Avatar
I ended up mounting mine next to all the lights on the dash, I will get some pics tommorow
__________________
1997 F-250 HD 4x4
DP Tuner F5 Chip, IDM Mod, RiffRaff Diesel 6637 Filter Kit, 3" DP, 4" Exhaust, Pyro, Tranny, Boost Gauge
  #6 (permalink)
Old 07-08-2009, 08:37 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
DP Tuner does not have a rotary knob like all the others.
They have a square digital switch with a square, flat wire connection in the back. It can be quite a pain to mount, not like drilling a hole for the other rotary switches.
But DP Tuner have some trick mount options if you check them out.
On my OBS, I mounted mine in the black dash strip to the left of the steering wheel. I notched the edge of the black strip to allow the flat wire to fit between the strip and the dash (in the crack) and just drilled a big hole behind the strip to feed the wire up through. You'll never see that hole with the strip on it.
Clear as mud?
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
