where did u mount your DP tuner switch?
My DP tuner is on the way
I found several threads but none of them show our years. Anyone have any pics? Thanks Rich |
i mounted my TW on my pillar pod. i don't imagine it would be much different.
http://i236.photobucket.com/albums/f.../IMAGE_055.jpg the matal is a piece of metal off my truck that i think i cut out of the bed when my ball hitch was installed. |
i have yet to glue a bezel around it obviously
I installed mine in the driver's door arm rest. I like it, it's convenient but I would have to think long and hard before I did it again as it is a Royal Pain in the A$$ to thread that cable through all of the nooks and crannies that it must go. :-banghead
Rog }> |
I ended up mounting mine next to all the lights on the dash, I will get some pics tommorow
DP Tuner does not have a rotary knob like all the others.
They have a square digital switch with a square, flat wire connection in the back. It can be quite a pain to mount, not like drilling a hole for the other rotary switches. But DP Tuner have some trick mount options if you check them out. On my OBS, I mounted mine in the black dash strip to the left of the steering wheel. I notched the edge of the black strip to allow the flat wire to fit between the strip and the dash (in the crack) and just drilled a big hole behind the strip to feed the wire up through. You'll never see that hole with the strip on it. Clear as mud? |
