Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2007 and Newer Expedition and Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln NavigatorSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2009, 01:04 PM
rod.d rod.d is offline
rod.d is starting off with a positive reputation.
Information system chime
We took our 08 Expy EL in for service last week to have the memory seats fixed, and since then the chimes that go with the information system warnings don't work anymore. For example, when you have a door partially open it will say "drivers door ajar" and it will play a chime, at least it used to. The key-in-ignition chime still works, but I believe that is a different circuit. Also, when we press the buttons to change the display on the information system, the beep doesn't work anymore. We are traveling and we took it to a local dealer and they basically said it wasn't supposed to do that, since they couldn't find it in the owners manual or service manuals. I guess we imagined it for 3 months before...
Any ideas on how to fix this? I don't know if there is a fuse for that, I guess I should check that. I have gone through the menus on the information system and there isn't a setting to turn it off/on. Thanks
Rod
  #2 (permalink)
Old 07-02-2009, 03:22 PM
bamp's Avatar
bamp bamp is offline
bamp is starting off with a positive reputation.
I'd check the fuses first.
__________________
09 Expedition Eddie Bauer W/Remote Start
08 GMC Crew Cab SLE W/Remote Start
  #3 (permalink)
Old 07-02-2009, 04:29 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is starting off with a positive reputation.
My 08 doesn't beep when you change the display. I will check and see if the door ajar makes it beep later tonight.
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #4 (permalink)
Old 07-02-2009, 04:35 PM
berry1234's Avatar
Ok, checked. When you start the car you get seatbelt chime if not buckled. If a door is open when you start the car, no beep. If a door opens after the car is started you get a beep. No beep while changing display, etc. I think you are fine.
__________________
  #5 (permalink)
Old 07-02-2009, 04:55 PM
That is part of the problem though, that when a door is ajar, with the warning message in the message center, there is no beep. Also when the lift gate it open and the truck is put into gear, it doesn't beep. The low fuel warning shows up, but no beep with it. I guess the problem is that we get the warning messages, but not the beeps that go with them.
  #6 (permalink)
Old 07-02-2009, 05:04 PM
berry1234's Avatar
Hmm. Are you opening the doors after the car is started?
__________________
  #7 (permalink)
Old 07-03-2009, 07:18 PM
clearnetedm clearnetedm is offline
clearnetedm is starting off with a positive reputation.
Ya I think something has changed on your truck. A good test would be to open a door while in motion or in gear. There should certainly be an audible as well visual indication.
On our 08 if we are sitting in park and the passenger door opens there is just an visual light but if you place into gear then the audible tone comes. We don't get any tone when scrolling through the option menus thought.
  #8 (permalink)
Old 07-06-2009, 01:17 PM
bamp's Avatar
^^^^ Yup, mine too!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
