Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 07:11 PM
Glenn O Glenn O is offline
Glenn O is starting off with a positive reputation.
460 Internally or externally balanced
Hi guys. I saw Horse Power television last Sunday morning on the SPEED channel and they were doing a 460 build up. There 460 was said to be externally balanced therefore they had a large counterweight that slid on the crank snout behind the timing cover. I put together a 1972 460 that did not have this counter weight. I was wondering if this is a concern. Has anyone ran in to this or know the answer. Thanks
  #2 (permalink)
Old 06-30-2009, 07:31 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
460 weighted spacer introduced midyear 1979 on F100/350's and Econolines. No 460 passenger cars after 1978.
There is no before/after production date or serial number break, as this was a running change.
The only way to know is by the block casting number: D9TE-6015-AB.
In addition to the weighted spacer, the harmonic balancer, crankshaft and flywheel are also different.
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #3 (permalink)
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Later model 460's had counter balancers. If your's had it, it needs to be on there as well as the flywheel/flex plate.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 06-30-2009, 07:38 PM
Ford Parts Guru
460 block casting numbers of D1VE-6015-AB, AB1, AB2 / C9VE, C8VE do not use a weighted spacer.
As stated above, the weighted spacer began midyear 1979, the block casting number is D9TE-6015-AB
__________________
  #5 (permalink)
Old 06-30-2009, 07:51 PM
My casting number is D1VE-6015-AA. Not sure what the AA means. Thanks
  #6 (permalink)
Old 06-30-2009, 07:55 PM
Ford Parts Guru
Quote:
No weighted spacer used on D1VE blocks, regardless of what the suffix is.
__________________
  #7 (permalink)
Old 06-30-2009, 08:02 PM
Thanks guys!
  #8 (permalink)
Old 07-01-2009, 01:03 AM
Ronzi Ronzi is offline
Ronzi is starting off with a positive reputation.
Is one more desireable over the other or not really?
  #9 (permalink)
Old 07-02-2009, 12:13 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is starting off with a positive reputation.
yes and no.
if you are going to build a stroker motor, most people prefer the D9TE block as it had longer cylinder walls. the stroker kit can be either internally or externally balanced depending on what kit you order and who is doing your balancing.
other than that either the internal or external balanced engines are good engines and offer about the same performance potential to start with. just remember the externally balanced rotating assembly will fit the internally balanced blocks but not the other way around. just make sure to use the correct flywheel and spacer for your application (in other words keep the rotating assembly togather as one)
rgds
Mike
  #10 (permalink)
Old 07-06-2009, 04:27 PM
Shawn63200 Shawn63200 is offline
Shawn63200 is starting off with a positive reputation.
For a stroker rebuild
is it better to have the internally or externally balanced, or is that based on what your block is? Maybe a silly question, but just curious. Thanks.
  #11 (permalink)
Old 07-13-2009, 09:12 PM
C-Leigh Racing C-Leigh Racing is offline
C-Leigh Racing is starting off with a positive reputation.
Lot of builders like the internal balanced, because the crank is balanced more instead of adding something to it on the outside to balance it.
Neil
  #12 (permalink)
Old 07-21-2009, 04:44 PM
Loganwildman's Avatar
Loganwildman Loganwildman is offline
Loganwildman is starting off with a positive reputation.
Re Internal vs External
If your not going to be spinning the motor hard, then external is fine. However if your going to really turn the motor ie north of 7000 than I'd go internal.
Alan
Horsin' Around Pulling team
Tags
1972 , 429 , balanced , d1ve , external , internal , internally
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
