hey just buying some parts for my rear end and am not around the truck at the moment, just wondering if 1977 ford f 150s came with 31 spline 9 in or 28 spline
According to my decoder ring, it could have either. Is there still a tag on it? Post everything on the tag. Otherwise, pull an axle. Someone here posted a tip about the ends of the axles--31s look one way, 28s another. Wish I'd kept that info..... If I find it, I'll post.
It's a 150, so it came from the factory with 31's.
That is in-correct, an F150 could have 28 or 31 splines.
It could even have a Dana 44 (1977/79)!
The AXLE tag on the rear end is necessary to discover which one, without pulling an axle.
The spline count isn't on the tag, but when the tag is decoded, the rear axle parts list will be known, from that, the correct axle shaft part number will be known.
__________________ Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
I've never came across a 150 4x4 that didn't have a 31 but I'm always the first to say "never say never" when it comes to Ford. How would a 44 end up under there ? Special order ?
__________________
'79 F250 13" lift 42" Super Swampers
Greetings: Anything to that link I posted about the way the ends of the axles look? OP does not say 4x2 or 4x4 btw....
Shows the above link to be inaccurate. The post shows 28 spline axles with the axle ends said to be 31 spline in the link. My faith in the internet is shattered and yet reaffirmed at the same time.
