Ash removal from DPF
Do the Ford DPFs collect ash over a period of time that needs to be cleaned out? If so, what is the trigger to determine when the DPF needs to be cleaned. Is the clean out a manual process involving removing the DPF?
I assume ash (non-combustable) cleaning is different from thermal regeneration that burns the soot collected in the DPF so it will pass thru the filter during regeneration.
The buildup is from the ash in the engine oil so if you burn oil you will need to clean the DPF sooner. The new CJ rated oils contain half the ash of previous oils. Filters will need cleaning by reverse flow of high-pressure air in a machine designed for the task--a process that takes about an hour and a half. This cannot be required in fewer than 150,000 miles.
wharrell
6.7L Power Stroke Diesel
15
04-24-2015 05:14 PM
