Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-27-2009, 12:24 AM
URX111 URX111 is offline
URX111 is starting off with a positive reputation.
89 Ranger What Oil To Use???
I have a 1989 Ranger I4 2.3L with 180,000 miles on it.
What oil is recamended to use? Any additive to use?
Last oil change I used 10/40 and STP , what's good for this engine?
TNX Paul
  #2 (permalink)
Old 07-01-2009, 03:15 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Are you unhappy with the oil you used last time? You might want to bump up to a 15w/40, or, if you feel the need for a heavier weight oil (since you used the STP to increase the viscosity) perhaps a 20W/50. Valvoline makes an oil designed for higher mileage engines, haven't heard anything bad about it...
Oh, and make sure you use a good quality filter such as Motorcraft or Wix (NAPA's filters are made by WIX) and stay away from Fram.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 07-01-2009, 08:59 PM
Thanks Tigerdan
I just want this engine to last a few more miles. I used the STP because I was worried about the lifters and low zinc oil. I'll look into the high milage oil, sounds good.
TNX Paul
  #4 (permalink)
Old 07-01-2009, 09:12 PM
TigerDan's Avatar
1968 Ford F-250
Low zinc oil isn't really as much of a problem with an engine that's well broken in (and at 180K, I'd say that yours is certainly broken in!) but if you want a good oil with some zinc content in it, look to a diesel rated oil such as Delo 400 or Rotella T.
__________________
FTE Moderator
  #5 (permalink)
Old 07-02-2009, 08:25 PM
Thanks Again For Your Responce ! ! ! !
OK I'll look into it. TNX Tigerdan
Paul
  #6 (permalink)
Old 07-04-2009, 10:24 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Unless it is burning alot of oil I would stick to 5w30 or 10w30. Valvoline Maxlife has extra anti wear and friction additives. Seems to work well in my 99 Ranger four cyl.
  #7 (permalink)
Old 07-04-2009, 01:04 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
The OHC 2.3 doesn't have the need for zinc that flat-tappet pushrod engines have due to the contact area between the cam and rocker. I run 10w30 in mine, with no issues, and it has a much newer cam (about 15k on it).
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
Tags
10 , 10w30 , 1989 , 20w50 , 30 , 89 , end , ford , i4 , oil , ranger , rear , safely , trucks , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
