Hard to get into gear when stopped
Old 06-19-2009, 09:41 PM
thedoctor's Avatar
thedoctor
thedoctor is offline
I have the same problem. Sometimes I have to turn the engine off to get it to go in any gear. What could this be?
Old 06-20-2009, 02:33 AM
vlasveld's Avatar
vlasveld
vlasveld is offline
Talked to a mechanic today, he said he figures its the throw bearing or something on the clutch????
Old 06-20-2009, 02:44 AM
Dirt racer's Avatar
Dirt racer
Dirt racer is offline
I have a 92 F150 with the 302 5 sp that I bought last oct. It has been hard to get into gear too. I drained the trans. fluid and put in new synthetic fluid. Works many times better. Just an idea to try.
Old 06-20-2009, 07:47 AM
fordman1090's Avatar
fordman1090
fordman1090 is offline
Ya, i could say that there is a possibility that the original owner put, or his shop put gear oil or some other heavy oil in the trans. That would cause it to be harder to shift all the time. I know put a little 10w-40 in mine because it takes out some of the slop.
There is also a good chance that the master or slave is failing. If you park the truck and pump the clutch pedal several times with the engine off, then look through the inspection port on the trans for a drip of brake fluid from the slave. If no drip i'd try the master 1st. If it is leaky, your gonna have to pull the trans. And if thats the case, replace everything including clutch, slave and master while your there. They can cause each other to fail.
Good Luck!
Old 06-20-2009, 08:38 AM
rikard's Avatar
rikard
rikard is offline
It sounds like the clutch isn't releasing completely. As other posters have said it could be a problem with the master or slave cylinders. Check the fluid level and try bleeding the system before tearing everything apart. The hydraulic system uses brake fluid and the transmission uses ATF.
regards
rikard
Old 06-21-2009, 08:06 PM
vlasveld's Avatar
vlasveld
vlasveld is offline
I was told it could possibly be the throw bearing (baring??), does that sound correct?
Old 06-22-2009, 08:13 AM
Kahuna's Avatar
Kahuna
Kahuna is offline
Look at the firewall where the master cyl mounts ,is it flexing when you step on the clutch or cracking? this is a very common problem with Fords,i belive ford makes a reinforcement plate to fix this problem.
Old 06-22-2009, 12:04 PM
andym's Avatar
andym
andym is offline
I doubt it's the throwout bearing. That doesn't sound right at all.
Originally Posted by andym
You said the fluid level is fine - what about the transmission fluid level? Did you pull out the fill plug and make sure the fluid is right at the hole?
Please answer this question.
Old 06-22-2009, 02:54 PM
vlasveld's Avatar
vlasveld
vlasveld is offline
The fuild in the tranny was good, when the problem started i put synthetic in to see if it would fix the issue so it was fresh tranny fluid in there.
I took it to the shop today and it turns out it was the clutch. New clutch kit installed, they had to do something with the fly wheel because it was worn out??? new trans mounts, and i had them replace those 3 black plugs on the tranny that always leak with metal ones. All in all $1200cdn + tax...~!~!! FML!
Thanks to everyone who responded and tried to help me out, I really appreciate it!
NotSoSporty98
08-28-2016 03:06 AM
shultzaberger
1983 - 2012 Ranger & B-Series
17
03-30-2016 07:47 AM
NinthGenF-SeriesOBS
1999 to 2016 Super Duty
03-25-2016 11:12 PM
bigredtruck
3.0L V6
03-03-2011 10:10 AM
Ryan S
2004 - 2008 F150
10-25-2010 04:14 PM
Quick Reply: Hard to get into gear when stopped
