Best fix for this
If you have that sort of rot at the corner then it is more than likely that there is more to be found along the inner lower door seam as well. Dirt falls down the window channel and collects along that seam...any moisture is held by the dirt and soon the rot begins. Ford didn't spend a lot of time or money on undercoating so check the entire seam before you just patch the obvious. Some of the local shops won't even touch these jobs unless the customer agrees to a complete lower door skin patch, too many customers coming back in a year or so complaining about new rust coming through. Good luck...
bassn1
06-23-2010 08:19 PM
