Electrical short?
Electrical short?
I just bought a 98 F150 supercab (5.4L/auto/4wd)from auction and I notice when I hit the brakes the interior light comes on (dim). Any ideas where to look? Also the pass side window won't go down (either side switch tried & doesn't work, also checked fuses-ok), are the motors prone to go bad on these trucks? I have some other stuff to bring up but that will be at a later time. Thanks in advance.
Thanks for your response, I'll keep you posted on the results. I noticed it seem to change the lighting problem else where, now when I turn on the cargo/interoir light, it lights up the third brake light and not the cargo lights. After I check the kick panels, I may pull the headliner and make sure the wiring has been messed with. I have a feeling I bought a nightmare!
