Electrical short?
Old 06-16-2009, 04:39 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
Oldtrucknut7077 is offline
Electrical short?
I just bought a 98 F150 supercab (5.4L/auto/4wd)from auction and I notice when I hit the brakes the interior light comes on (dim). Any ideas where to look? Also the pass side window won't go down (either side switch tried & doesn't work, also checked fuses-ok), are the motors prone to go bad on these trucks? I have some other stuff to bring up but that will be at a later time. Thanks in advance.
Old 06-17-2009, 06:35 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The first issue is probably a bad ground circuit.
Pull both side kick panels and inspect the ground lugs and wiring connections that provide the various ground connections to the cab's body. You'll probably find one that has rotted away.
Old 06-21-2009, 11:10 AM
Oldtrucknut7077
Thanks for your response, I'll keep you posted on the results. I noticed it seem to change the lighting problem else where, now when I turn on the cargo/interoir light, it lights up the third brake light and not the cargo lights. After I check the kick panels, I may pull the headliner and make sure the wiring has been messed with. I have a feeling I bought a nightmare!
Old 06-21-2009, 12:26 PM
96f150's Avatar
96f150
96f150 is offline
Or, your windshield may be leaking and getting the GEM module wet.
Rich
Old 06-22-2009, 03:06 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
I agree with projectSHO89, grounds missing will cause all kinds of weird things especially when lighting is concerned. I have heard of other guys with rust problems in the foot wells too. Good luck!
305dgar
1997 - 2003 F150
13
03-10-2014 09:29 AM
frozenmunkee
Modular V8 (4.6L, 5.4L)
11-05-2013 07:57 PM
kenneBF250V10
1999 to 2016 Super Duty
10-25-2010 12:14 PM
1953dave
06-04-2005 02:40 AM
daniel01
1997 - 2003 F150
11-06-2002 04:25 PM
Quick Reply: Electrical short?
