52 f6 stalls won't restart
Need a little help. My 52 f6 w/226 will start and idle fine but as soon as there is a load on the motor it stalls and no restart. I had the carb rebuilt at a shop and I replaced the fuel pump, it also has a new inline filter. It will idle smooth and rev up ok but it cuts out when driving. Also there is not much fuel visible in the clear fuel filter while running. Any ideas?
Do you have a vented gas cap? Take the gas cap off the tank and try it.
You may also have a blocked fuel line or junk in the tank at the outlet. If you are using rubber hose between the metal pieces, they can not be any more than a couple inches (like 6") long. If the gas cap thing doesn't work, I'd check the fuel line, for a strong flow.
I would say that's a pretty good guess.
I don't know if the pre-bent tubes are available. But I know you can buy the steel tubing, and a tube bendin gtool is not too expensive to get. I would try making my own - I did and it was easy!
I've had this happen to me before. It sounds exactly like a fuel restriction. My problem was that someone had siphoned gas out with a rubber hose and dropped it in the tank. The hose softened and would slosh around the tank and occasionally block the pickup tube---no screen. It was intermittent and took forever to figure out what it was. My symptoms were exactly like yours...idle fine but would not take a load at all. In my case the filter was clean.
