92 f-150 with 94 motor no start
on
Can you verify that the ignition advances past the base setting once the spout plug is put back in? If it does you'll see it with the timing light.
You don't need any tools to pull the codes, simply ground the STI wire in the EEC test harness, turn the key to run, and count the flashes on the check engine light.
Wildman25
11-15-2014 05:29 AM
Monkeys7.3
04-18-2013 02:46 PM
