Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 10-07-2009, 08:10 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
Yes Tom. I think you should gain some experience with normal distillation first.
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #47 (permalink)
Old 10-07-2009, 08:35 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Quote:
Thanks Don. I'll give it a shot. Haven't heard from Phydeaux 88 yet??? I suspect something bad after reading his last post.
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #48 (permalink)
Old 10-28-2009, 08:30 PM
OK Don. Here's the latest. I removed 7 gallons of glycerol from the 40 gallon batch and heated the Bio to 190 deg. The methanol ran out in a steady stream (I guess the condenser is working). I recovered approx 1/3 gallon (I was expecting more). I was going to run it through your setup but I was afraid with the high temp and the pressure I may cause a problem so I pumped it directly into the magnesol tank and will mix it tomorrow. Kind of tough on the Harbor Freight pump to pump at that high a temp. Was going to let cool but was afraid of sucking in moisture. I still want to get your system going. This was VERY time consuming.(took about 4 hours to heat to 190 deg.)
On another note. Are you still moving all your crap to the new place?
Take care
Tom
__________________
  #49 (permalink)
Old 10-28-2009, 08:45 PM
Biodiesel Guru
Take care
Tom
Sounds like your finally getting it to work OK. Most of the Methanol is in the Glycerol. With 40 gallons of bio you will get less than 3/4 of a gallon of Methanol so you are getting close ( you won't get it all out). Now you need to try recover the Methanol from your glycerol ( you should get 20-30%)
What "crap"? Everything I have are "treasures"! Yes everything has been moved to the new place...........Still haven't heard from PHY, sure hope he is OK.
Keep at it Tom, you are showing progress!
Take care buddy.
Don.
__________________
FABMANDELUX.
Don.
Tags
condenser , methanol , pull , recovery , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
