Steering issues failed state inspection
Since I'm still in Iraq, my dad took my "new" toy to get inspected for me. It failed. GRRRRRRRRRRRRRR. Among other things, the biggest issue was the horrible slop in the steering. My dad said you can turn the wheel a quarter of a turn before it does anything. He also said that the power steering pump is leaking. At first guess, I'm gonna say that I need a new power steering pump and lines, and a new steering box. Im sure there are a million threads on her reguarding all this, but I don't exactly have unlimited access to the internet to spend hours pouring through them. Is the steering box and PS pump obsolete for this truck? Am I going to have to come up with some odd mix of parts to get it fixed? Oh ya, before I forget. It's a 74 HIGHBOY. 360, 4 speed, dana 60 front axle swap. Thanks in advance for your help guys.
I wouldn't assume you need a new pump just yet. Power steering leaks are common and most of the time easy to fix. The high pressure and low pressure lines don't cost much to replace. I had a bad leak that a $0.50 clamp fixed.
There are aftermarket steering boxes and pumps. The boxes are not that cheap, $250+ I recall when I looked at rockauto.com.
You have the infamous highboy power assist steering setup, it's a push/pull system utilizing a hydraulic ram and a control valve/drag link, you'll need to isolate exactly where the excessive play is coming from, it could be from a number of places, parts for this steering system are expensive, the ram and control valve are rebuildable though, then of course you always have the option of doing the 78/79 power steering swap which is very popular on these highboys.
Just a thought but was your truck running during this inspection, specifically during the steering inspection? when the engine isn't running and the system isn't under pressure, there is some play in the ball stud on the control valve (and therefore your steering wheel as well) this is normal, however, when the system is powered up, the play disappears because the hydraulic action moves the linkage as it is supposed to, but of course if you have slop in other parts of the steering linkage they'll need to be addressed first.
How much slop can be adjusted out with this screw? Can't too much adjusting make the steering bind up?
An 1/8 to 1/4 turn of the screw makes a huge difference if the steering box is ok. Not sure of the particulars, but if you end up having to turn in the screw more than a couple turns something is wrong.
Josh
