Bronco II Ford Bronco II
Code 89 problems
Old May 31, 2009 | 04:14 PM
kools20's Avatar
kools20
Code 89 problems
Hi have an 89 bronco ll xlt 2.9 5 speed manual trans.4x4 pulled codes and have code 89 tourqe convertor lock up soleniod since its a manual trans i figured it has to do something about the heat riser solenoid can anyone explain to me where to find it . I have been searching all kind of sites looking for some kind of explanation of it with no luck hope someone can point me in the right direction.
Thanks
Old May 31, 2009 | 10:09 PM
mrshorty's Avatar
mrshorty
On a BII, 89 refers to the TCC circuit. Is it possible someone has swapped a manual transmission in place of an auto, or put an auto computer into it? Any chance you've misread the code?
Old May 31, 2009 | 10:48 PM
kools20's Avatar
kools20
no i have owned this truck for over 9 yrs and am the 2nd owner of it so trans is OEM but did have a problem a few yrs back and if i remember correct ford did put a new computer in it. i have tried to unhook bat to try to clear codes but still get the same code again is there a way i can find out if i have the right computer in it (ie) for a manual trans
Thanks
Old Jun 1, 2009 | 11:32 AM
mrshorty's Avatar
mrshorty
In theory, you should be able to pull the numbers (part number and/or calibration code) off of the computer and Ford should be able to identify which application it came out of.
