Checking Differential Oil Level
My manual shows different oils and levels for different axles. My 350 has a C9 rear end and I am trying to figure out if it is a Dana or Conventional. Anyone got any information on what the difference might be? How about the front? 1997 F350 PSD. I have 80w-90, is this okay?
Thanks,
Aaron
Thanks,
Aaron
The 80W-90 should be fine. If you do a lot of towing or hauling heavy you might consider going with a 140wt gear oil.
If you have synthetic in the differentials, I would not mix them with standard gear oil. As for oil levels, I fill them up to the fill plug. When oil starts running out, it's full.
Aaron-71
237
01-24-2018 08:32 AM
Aaron-71
07-01-2011 12:59 PM
Fordman65
01-05-2005 11:22 PM
