Checking Differential Oil Level
Old May 31, 2009 | 02:44 PM
aaron ford's Avatar
aaron ford
My manual shows different oils and levels for different axles. My 350 has a C9 rear end and I am trying to figure out if it is a Dana or Conventional. Anyone got any information on what the difference might be? How about the front? 1997 F350 PSD. I have 80w-90, is this okay?
Thanks,
Aaron
Old May 31, 2009 | 03:24 PM
CampSpringsJohn's Avatar
CampSpringsJohn
The 80W-90 should be fine. If you do a lot of towing or hauling heavy you might consider going with a 140wt gear oil.
If you have synthetic in the differentials, I would not mix them with standard gear oil. As for oil levels, I fill them up to the fill plug. When oil starts running out, it's full.
Old May 31, 2009 | 03:39 PM
Brown Falcon's Avatar
Brown Falcon
You should have a 10.25 rear and a dana 60 front.
Old May 31, 2009 | 11:15 PM
BadDogPSD's Avatar
BadDogPSD
Your front axle is a Dana 60, your rear is a Sterling 10.25 with 3.55 limited slip. Ford recommends 75w-140 gear oil, make sure you use oil that has the friction modifier for your limited slip, or buy some to add.
As said above, it's full when it starts to run out of the fill plug.
Old Jun 1, 2009 | 06:03 AM
aaron ford's Avatar
aaron ford
Thanks Everyone. I checked them and found the rear to be slighty low and the front was fine. I topped it off with what I had on hand. The fluid appeared to be red like tranny fluid, but definitely smelled like gear oil. Wonder what the PO used...Aaron
Aaron-71
Jul 10, 2025 08:39 PM
Aaron-71
237
Jan 24, 2018 08:32 AM
Aaron02QD
Modular V10 (6.8l)
Jul 24, 2016 04:18 PM
Aaron77
May 5, 2006 04:11 AM
Fordman65
Jan 5, 2005 11:22 PM
