Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 05-27-2009, 08:37 AM
SPELLY F150 SPELLY F150 is offline
Garage is empty, add now
SPELLY F150 is starting off with a positive reputation.
Question Tonneau Cover
My Dad is looking to put a Tonneau cover on his 09 STX (Blue Flame). He is not sure if he wants to go all the way with a fiberglass cover. He has had a Downey SST cover on his past trucks, but it appears that the company has gone under. What are you guys running for Tonneau covers? Thanks for the help....
  #2 (permalink)
Old 05-27-2009, 08:48 AM
willywaxer's Avatar
willywaxer willywaxer is offline
willywaxer is starting off with a positive reputation.
A lot of folks here, like me, are using the Bakflip. Search the threads, lots of good choices on this board.
Click the image to open in full size.
  #3 (permalink)
Old 05-27-2009, 08:49 AM
cpdorroh's Avatar
cpdorroh cpdorroh is online now
cpdorroh is starting off with a positive reputation.
I am running a full fiberglass A.R.E. LSII cover. The build quaility on it is superb, and leaks have not been an issue whatsoever.
I wanted a hard cover for security, and I liked the looks of the fiberglass covers. I was afraid that one of those covers that rolls away or flips back would leak over time, but those seem to be what most of the guys on here use, and most seem pretty satisfied. One of these covers does make it easier to haul items that won't fit under the cover. IMO it all comes down to how often you haul things that won't fit.
__________________
2009 F-150 Lariat SCrew
Previous Ford trucks:
2004 F-250 Super Duty, King Ranch, 6.0 PSD, 4x4, 3.73LS
2001 F-150 Super Cab, XLT, 5.4L, 4x4, 3.55LS
  #4 (permalink)
Old 05-27-2009, 08:52 AM
Az.scarecrow's Avatar
Az.scarecrow Az.scarecrow is offline
Az.scarecrow is starting off with a positive reputation.
Quote:
I have the Under Cover UnderCover Toneau Covers and Swing Case and love it. I have had the fiberglass ones in the past and the undercover is much stronger.
The two things I like most about the Under Cover I have is; the strength, rigidity, and the simplicity to remove it when needed. With one person on each side it takes me NO LONGER than 10 seconds to remove.
I hope this helps -
__________________
00 F250 PS 4x4 CrewCab Shortbox XLT
Aluminum MB Motoring-285/75-16 BFG A/T's
Rhino Hardlined with UnderCover Bed Cover
Autometer 3 pod pillar, AFE 6637 intake & 4" exhaust with muffler delete. DP Tuner from ITP - 40t+80e+140+drive-thru+high idle, JW Valve Body, HPX, OBAnni, CCV Bypass, Foil Delete, AIH Delete, & Ported Turbo Shroud.
Last edited by Az.scarecrow; 05-27-2009 at 09:00 AM. Reason: The link was bugging out!
  #5 (permalink)
Old 05-27-2009, 08:55 AM
cpdorroh's Avatar
Quote:
Originally Posted by Az.scarecrow View Post
I have the Under Cover UnderCover Tonneau Covers and Swing Case bed cover and love it. I have had the fiberglass ones in the past and the undercover is much stronger.
I hope this helps -
^^^ I have a buddy that has one of these, and it is VERY easy to remove, especially with 2 people. They are also pretty reasonably priced.
__________________
  #6 (permalink)
Old 05-27-2009, 09:10 AM
Quote:
I know that most covers are not built to sit or stand on, but thats one thing I could boast about mine. I would even feel comfortable with two or three adults standing on it at the same time.
The bad thing about the undercover is if you break a corner off or crack the rolled edge, its NOT as simple to repair as fiberglass. But it is stronger.
All though I like the look, I always worried about the fold up one's leaking at the joints. I never owned the fold up or roll up, so who knows.
__________________
  #7 (permalink)
Old 05-27-2009, 10:35 AM
aliasmax aliasmax is offline
aliasmax is starting off with a positive reputation.
I have the access roll up cover on my 2009 f150 xlt. I also had the access on my dodge. the are not water tight. They do leak on the corners. They redesigned the covers 2 years ago and thats the one i have on the ford. I get a small amount of water in from the back corners. front is pretty water tight. I don't carry anything in the back that water will hurt so to me it don't make a differance.
  #8 (permalink)
Old 05-27-2009, 10:40 AM
willywaxer's Avatar
In terms of leaks, you will have them if you have the optional tailgate manstep, as there are grooves on either side of the cap that extend into the bed. This is the only place I notice water getting in with the Bakflip.
  #9 (permalink)
Old 05-27-2009, 11:42 AM
broncobran68's Avatar
broncobran68 broncobran68 is offline
2009 Ford F-150
broncobran68 is starting off with a positive reputation.
I had the pace edwards bedlocker on my last truck. It was awesome. The $1800 price tag is the only thing holding me back from getting another one.
__________________
'09 F150 SCREW FX4. 2.5" AS Leveling kit/3" blocks. Line-x. 35" Toyo M/Ts on 18x9 Moto Metals. Homelink mod.
'68 BRONCO. 5.5" lift, 35s, 289 EFI, rollcage, durabak interior
  #10 (permalink)
Old 05-27-2009, 06:43 PM
SteveVFX4 SteveVFX4 is offline
SteveVFX4 is starting off with a positive reputation.
another satisfied Bakflip HD owner here. One of the best I've owned so far and I tried several styles over the years. Just can't beat the low profile looks and functionality (easily folds out of the way) when you need to haul big items.
Email me if you want some good info on where to buy one.
__________________
2009 F-150 Platinum 4x4 White Sand Tri-Coat
old ride: 2004 F-150 Supercrew FX4 Silver/DSG
  #11 (permalink)
Old 06-05-2009, 06:14 AM
Toto Toto is offline
Toto is starting off with a positive reputation.
I had an Access on my Dodge Cummins for four years.
I loved it and would get another in a heart beat.
As it happens, Ford had a 1K coupon for accessories and I got the Ford soft cover, plus some other stuff.
It may as well have been an Access...nice design and works well.
Once again though, the Access is an outstanding product and guaranteed for life....just not cheap.
I went through four winters with lots of snow, and it still looked new.
Hope this helps.
BTW, Truxedo make some nice soft covers also.
  #12 (permalink)
Old 02-07-2010, 06:59 PM
jester8484's Avatar
jester8484 jester8484 is offline
2005 Ford F-150
My Garage
jester8484 is starting off with a positive reputation.
thanks guys this thread was really helpful.. i just bought a f150 recently and was interested in a roll up cover.
thread win!
Tags
2002, case, cover, covers, downey, f150, fiberglass, ford, forums, removing, sst, supercrew, swing, tonneau, truck, undercover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
