Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
How to clean EGR Valve?
Old 05-19-2009, 11:43 PM
oracle's Avatar
oracle
oracle is offline
Hi,
I got the code about the EGR valve, I'll replace it if it throws an error again but on the meanwhile I suppose that valve should be able to get a second air by cleaning it..
Any hints on how to clean it?
Thanks
Old 05-20-2009, 07:27 AM
wptski's Avatar
wptski
wptski is offline
Originally Posted by oracle
Hi,
Thanks
Pretty hard since you can't get to the needle/seat! They are sometimes open on the side where you can see the rod from the diaphram. You'd need a vacuum pump to hold the valve open and maybe spray carb cleaner hoping it trickles down to the seat, then work the open/closed repeatedly.
The fitting from the EGR tube to the valve can be a real bugger! I ended up sawing my EGR tube on my '97 Ranger after removing the wheel, wheel well, 2/3 of the fitting, sprays and heat.
Old 06-30-2009, 10:29 PM
Trublufords's Avatar
Trublufords
Trublufords is offline
Never replaced an EGR valve on an Escape.P0401 was ALWAYS a bad PDFE sensor---Ford had a TSB on it and if it came up with a p0401--no egr flow just replace the delta pressure feedback sensor. LOL Blue
6.0fanboy
02-04-2017 12:17 PM
darrellbarnes
09-01-2015 02:36 PM
WH 6.0
09-20-2012 08:03 PM
Jasonszion
04-16-2011 12:15 PM
84 f250 6.9
23
09-12-2009 01:05 PM
Quick Reply: How to clean EGR Valve?
