How to clean EGR Valve?
Hi,
I got the code about the EGR valve, I'll replace it if it throws an error again but on the meanwhile I suppose that valve should be able to get a second air by cleaning it.. Any hints on how to clean it? Thanks |
Originally Posted by oracle
(Post 7520676)
Hi,
I got the code about the EGR valve, I'll replace it if it throws an error again but on the meanwhile I suppose that valve should be able to get a second air by cleaning it.. Any hints on how to clean it? Thanks The fitting from the EGR tube to the valve can be a real bugger! I ended up sawing my EGR tube on my '97 Ranger after removing the wheel, wheel well, 2/3 of the fitting, sprays and heat. |
Never replaced an EGR valve on an Escape.P0401 was ALWAYS a bad PDFE sensor---Ford had a TSB on it and if it came up with a p0401--no egr flow just replace the delta pressure feedback sensor. LOL Blue
