Fuse Block 1976
Old 05-19-2009, 09:07 PM
sklinemansk's Avatar
sklinemansk
sklinemansk is offline
Fuse Block 1976
Does anyone have a detail for the fuse block in this truck.. I found a blown fuse but am not sure what it is for as I can not read it.
Old 05-19-2009, 10:07 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Bgasrickshaw is offline
Heres a scan from my Haynes book
Old 05-20-2009, 07:24 AM
sklinemansk
Thanks for the pic.. Now what does the secound one from the left on the top row not counting the small fuse do..
Old 05-20-2009, 11:45 AM
ShamelessMT's Avatar
ShamelessMT
ShamelessMT is offline
That says st. blt. (seat belt). I'd assume it's the fuse for the seat belt buzzer.
Old 05-20-2009, 09:06 PM
Bgasrickshaw
No. I think that one is the engine solonoid. The label to the left of each fuse is the one for that fuse.
Old 03-29-2016, 12:24 PM
stronger66ratfink's Avatar
stronger66ratfink
stronger66ratfink is offline
fuse box diagram
I'm kind of in the same boat now also
never got a owners manual and have pulled up the diagram of the 78 fuse box but do not know or can I find a print out of what fuse is for what?
Old 03-29-2016, 04:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Here's a link to the second page of the factory wiring diagrams for the '78. It has the fuse box layout in the upper left hand corner and, just below, it identifies each fuse and the circuits it protects.
http://fordification.net/tech/images...ster_2of10.png
The following 2 users liked this post by mikeo0o0o0:
Old 03-29-2016, 11:43 PM
Ozzie H.'s Avatar
Ozzie H.
Ozzie H. is offline
From the 1976 Ford truck owner's manual
Here are the two pages from the 1976 Ford truck owner's manual for the fuses.
The following 2 users liked this post by Ozzie H.:
Old 11-02-2022, 09:02 AM
Mr.Gibble's Avatar
Mr.Gibble
Mr.Gibble is offline
Thank you very much for posting this, Ozzie!
Dumb question (but I am going to ask it anyway - is this the same layout for a 1977 Ford F-250?
Thanks
Old 11-02-2022, 09:22 AM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
My notes show 1976 and up, it matches my '77 anyway.
Same fuse box as the '76 one above ... but the angle or orientation is turned.
Hope it helps some.
The following users liked this post:
Old 11-02-2022, 10:33 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
And the other good stuff to have with the 1st 2 pages.
Old 11-02-2022, 11:48 AM
Mr.Gibble's Avatar
Mr.Gibble
Hope it helps some.
Yes, that is very helpful. Look like it matches up to my '77. THANK YOU!!:
Old 11-05-2022, 05:29 PM
Mr.Gibble's Avatar
Mr.Gibble
Which fuse would be constant power on?
Old 11-05-2022, 06:01 PM
redroad's Avatar
redroad
redroad is offline
There is key on, Accessories on, and a direct battery connection. What circuit are you trying to power up ?
Old 11-05-2022, 07:26 PM
Mr.Gibble's Avatar
Mr.Gibble
I am installing a backup camera [Autovox v5 Pro] and trying to tie two wires to the fuse box.
The wires are:
1. ACC/Ignition
2. 12V Constant Power
Which fuses would you use?
I thought:
1. Radio to act as the ACC/Ignition
2 . Emergency for constant power
But if there are better choices, I'd love to hear it:
Here is a snapshot of my 1977 F250 fuse box:
Actual Photo:
Quick Reply: Fuse Block 1976
