Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-19-2009, 08:45 AM
dockrocker's Avatar
dockrocker dockrocker is offline
Garage is empty, add now
dockrocker is starting off with a positive reputation.
Will the Expedition get the 6.2l motor?
I may be in the market for a new Expedition EL in the next year (just as soon as my magic Obama-bucks arrive in the mail! ). I've not been following the forums too much, so I don't know the status of the on-again, off-again 6.2 motor. IMO, the 5.4 is a little shy in the hp department for a truck engine, so ideally I'd like to see if Ford is going to put the larger motor in their large SUV.
I did some searching in the forum but haven't seen anything definitive, thus this thread. I had my eyes set on a used Excursion, but if the EL were to get a decent engine that might be the way to go...
Thanks!
__________________
"Good. Bad. I'm the guy with the gun." - Ash Williams, Housewares.
  #2 (permalink)
Old 05-19-2009, 10:54 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Nope, not for the 2010.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 05-19-2009, 04:29 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
doubt it will ever...there is talk the Harley F-150 and Raptor F-150 will get a 6.2...but it seems to be on/off
sounds more likely the 6.2 will take over for the V-10 in the 3/4 & 1 tons
have you driven a new Expy (2007 + model)?
they are actually quite peppy. The new 6-speed does wonders for the vehicle
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 05-19-2009, 07:00 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
They need to get the 6.2 or the 5.0 out there, these trucks really do need 400 hp. I bet you'd even see some increase in fuel economy as the engine is only work at a % of the load the 5.4 was. The expedition is the slowest Full size suv out there now that GM has added the hot rod 6.2 in their Tahoe and 6.0 in their suburbans. Ford needs a towing motor in these there is no doubt.
I don't call a neck and neck 1/4 mile race with a 4 CYL Toyota Venza a peppy vehicle. I call something running the 1/4 mile in the 15.5 range peppy. Heck, the Sequoia is knocking on the door of a high 14 sec 1/4 mile.
  #5 (permalink)
Old 05-20-2009, 03:03 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
Quote:
the 5.4 has over 80% of it's torque available at 1,000 rpm...couple that with the close ratio 6 speed...it's a tow monster
especially with the 4.17 1st gear ratio...the only real negative aspect is the 3.31 rear gears. but luckily you can get 3.73 if you shop around
the 2007+ Expy has a higher GCWR & max trailer rating than a 1999-2002 F-250 with 5.4 engine
so it won't win a HP game...but it will do what you ask of it all day long.
btw, the 6.0 has been available in the Burban and the Tahoe since about 2006...maybe earlier. It's a great high HP motor...like the Dodge, they like to rev high to get their numbers...the 5.4 is a lower RPM motor
um...yeah
you are comparing a 381 HP Sequoia with 4.30 rear gears against a 300 HP, 3.73 gear Ford
also, the Sequoia is smaller, and weighs about 1,000 lbs less...not exactly a good comparison
I had a 2006 F-150 Supercrew FX4 with the 5.4...my 2008 Expy is easily comparible with that truck (when it was stock) in the power and acceleration department
just today I had to accelerate from a stop to 55 mph traffic on the freeway...The Expy hunkered down and did it with no qualms
I can see some room for improvement because I like performance. I see a set of 4.30 gears + LSD in the very near future (October), and custom tuning...
but this ain't the Expy of yesteryear...it is a completely different beast
I was very reluctant to buy mine. I needed the space, but I was very hesitant about the performance aspect...now that I've put 850 miles on her, the PCM & Transmission controller have learned my driving styles...I am even more satisfied with it
For reference, I gave up my RoushCharged F-150 for the Expy...and that thing could haul some serious behind
__________________
  #6 (permalink)
Old 05-20-2009, 09:28 AM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
With the new "standards" that the current administration just announced which they intend to force down everyone's throats, I wouldn't count on anything like that anytime soon, if ever.
Obama Announces New Fuel Economy Standards - Auto - FOXNews.com
If this doesn't get sidetracked somehow, you might want to pick up one of these vehicles while they are still available.
  #7 (permalink)
Old 05-20-2009, 10:24 AM
berry1234's Avatar
Why not stockpile ammo and guns too.
__________________
  #8 (permalink)
Old 05-20-2009, 05:12 PM
nebmike's Avatar
nebmike nebmike is offline
nebmike is starting off with a positive reputation.
Quote:
Isnt everybody doing that?!?
Heck, thats why I bought my EL... more room for the guns and ammo! Though I will say, my 0-60 get-away time slows a bit once I mount my dual .50 cals and stow 10k rounds of ammo for them.
__________________
Mike
'11 F350 Lariat FX4, Crew, SB, 4x4, 6.7L, Camper Pkg
2007 Laredo 315RL 5'er, 35', 11.5k, Onan 4k
  #9 (permalink)
Old 05-20-2009, 09:22 PM
poppie poppie is offline
poppie is starting off with a positive reputation.
Thanks!
----------------------------------------------NOT IF OBAMA CAN HELP IT,see 39.5 MPG story's, For the farmer's,contractor's,plumber's,electric contractor's,AC contractor's & RV'ER'S it's game over,the mouse truck's coming down the line just will not cut it hauling & towing big heavy load's.
__________________
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 sunnybrook 31 bwks with 3 slide's, truck & RV 20,900 #'s all at the scale .
My truck and 5er.
  #10 (permalink)
Old 05-20-2009, 11:16 PM
carlos1212's Avatar
carlos1212 carlos1212 is offline
carlos1212 is starting off with a positive reputation.
Ford should put the 6.2 in their Navigators.
There is no reason to buy a navigator over an expedition.
back in 99-02 navigators had an advantage over expy's because they had a 4v 300 hp vs the expy's 2v 260hp.
Now its the same engine and tranny.
  #11 (permalink)
Old 05-21-2009, 11:07 AM
gddyup's Avatar
Right nebmike! I thought that was a given.
  #12 (permalink)
Old 05-21-2009, 11:41 AM
berry1234's Avatar
And don't forget the bomb shelter!
__________________
  #13 (permalink)
Old 05-21-2009, 02:40 PM
ruschejj's Avatar
ruschejj ruschejj is offline
2011 Ford F-250
ruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud ofruschejj has much to be proud of
Joel Rusche Joel Rusche Joel Rusche
Our Expedition has the 5.4 and the trailer tow package. When I hook up to our travel trailer (approx. 8000lbs.) I don't have any issues with going or stopping. I do have issues with the rear suspension and maxing out my weight distribution hitch. Wish I could put some aftermarket air bags under there. Also, I have issues with stability at speeds over 60MPH. Windy days are not fun.
The engine/trans. really can't maintain 70mph in overdrive on flat ground with light winds. It constantly shifts in/out of overdrive and the slightest hill tips it into a lower gear.
So, I don't have any use for greater take off speed or faster 1/4 mile times. I wish the rear end were better suited for towing. More often than not, I just use my F250. Not a fair fight between the two so I won't even reference what life is like with the trailer behind my truck. I just grin and bear it when we go to FL or the Carolina beaches with the Expedition. Anywhere else, the truck goes.
Our Expedition is an '08, short XLT, 5.4 w/heavy duty tow package but I think the dang rear end is a 3.13. Oh well, got it for $26,500
__________________
2011 F250 6.7 4X4 Lariat Ultimate FX4 3.55 ELock
Polk Audio component speakers, AFE Stage 7 intake
Sho Me Strobes, Shocker XL Horns, BakFlipG2
2 Kicker 10" subs, Rockford Fosgate amp
Ride-Rite air bags, VIAIR #10007 onboard air, AFE DPF back exhaust, power slot rotors/EBC pads, Nitto Trail Grapplers M/T 295/55 R20! Transfer-Flow 50 gal tank
  #14 (permalink)
Old 05-21-2009, 02:42 PM
ruschejj's Avatar
2011 Ford F-250
Oh yeah, the Smith & Wesson M&P 9mm rides with me.
__________________
  #15 (permalink)
Old 05-21-2009, 02:46 PM
gddyup's Avatar
I have an 07 EL Limited.... my bomb shelter is portable!
Rush, there should be a metal tag attached to one of the cover bolts on the rear-end housing. You can find the gear ratio typically right off of that by checking the serial numbers on it. Can probably get the number and find the gear ratio online somewhere I would imagine....
Oh yeah, the M&P... nice pistolo!
Tags
50, 62, 62l, coming, engine, expedition, ford, goin, larger, liter, motor, offer, put, v8, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
