2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Will the Expedition get the 6.2l motor?
Old 05-19-2009, 08:45 AM
dockrocker's Avatar
dockrocker
dockrocker is offline
I may be in the market for a new Expedition EL in the next year (just as soon as my magic Obama-bucks arrive in the mail! ). I've not been following the forums too much, so I don't know the status of the on-again, off-again 6.2 motor. IMO, the 5.4 is a little shy in the hp department for a truck engine, so ideally I'd like to see if Ford is going to put the larger motor in their large SUV.
I did some searching in the forum but haven't seen anything definitive, thus this thread. I had my eyes set on a used Excursion, but if the EL were to get a decent engine that might be the way to go...
Thanks!
Old 05-19-2009, 10:54 AM
berry1234's Avatar
berry1234
berry1234 is offline
Nope, not for the 2010.
Old 05-19-2009, 04:29 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
doubt it will ever...there is talk the Harley F-150 and Raptor F-150 will get a 6.2...but it seems to be on/off
sounds more likely the 6.2 will take over for the V-10 in the 3/4 & 1 tons
have you driven a new Expy (2007 + model)?
they are actually quite peppy. The new 6-speed does wonders for the vehicle
Old 05-19-2009, 07:00 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
They need to get the 6.2 or the 5.0 out there, these trucks really do need 400 hp. I bet you'd even see some increase in fuel economy as the engine is only work at a % of the load the 5.4 was. The expedition is the slowest Full size suv out there now that GM has added the hot rod 6.2 in their Tahoe and 6.0 in their suburbans. Ford needs a towing motor in these there is no doubt.
I don't call a neck and neck 1/4 mile race with a 4 CYL Toyota Venza a peppy vehicle. I call something running the 1/4 mile in the 15.5 range peppy. Heck, the Sequoia is knocking on the door of a high 14 sec 1/4 mile.
Old 05-20-2009, 03:03 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
the 5.4 has over 80% of it's torque available at 1,000 rpm...couple that with the close ratio 6 speed...it's a tow monster
especially with the 4.17 1st gear ratio...the only real negative aspect is the 3.31 rear gears. but luckily you can get 3.73 if you shop around
the 2007+ Expy has a higher GCWR & max trailer rating than a 1999-2002 F-250 with 5.4 engine
so it won't win a HP game...but it will do what you ask of it all day long.
btw, the 6.0 has been available in the Burban and the Tahoe since about 2006...maybe earlier. It's a great high HP motor...like the Dodge, they like to rev high to get their numbers...the 5.4 is a lower RPM motor
um...yeah
you are comparing a 381 HP Sequoia with 4.30 rear gears against a 300 HP, 3.73 gear Ford
also, the Sequoia is smaller, and weighs about 1,000 lbs less...not exactly a good comparison
I had a 2006 F-150 Supercrew FX4 with the 5.4...my 2008 Expy is easily comparible with that truck (when it was stock) in the power and acceleration department
just today I had to accelerate from a stop to 55 mph traffic on the freeway...The Expy hunkered down and did it with no qualms
I can see some room for improvement because I like performance. I see a set of 4.30 gears + LSD in the very near future (October), and custom tuning...
but this ain't the Expy of yesteryear...it is a completely different beast
I was very reluctant to buy mine. I needed the space, but I was very hesitant about the performance aspect...now that I've put 850 miles on her, the PCM & Transmission controller have learned my driving styles...I am even more satisfied with it
For reference, I gave up my RoushCharged F-150 for the Expy...and that thing could haul some serious behind
Old 05-20-2009, 09:28 AM
gddyup's Avatar
gddyup
gddyup is offline
With the new "standards" that the current administration just announced which they intend to force down everyone's throats, I wouldn't count on anything like that anytime soon, if ever.
Obama Announces New Fuel Economy Standards - Auto - FOXNews.com
If this doesn't get sidetracked somehow, you might want to pick up one of these vehicles while they are still available.
Old 05-20-2009, 10:24 AM
berry1234's Avatar
berry1234
Why not stockpile ammo and guns too.
Old 05-20-2009, 05:12 PM
nebmike's Avatar
nebmike
nebmike is offline
Isnt everybody doing that?!?
Heck, thats why I bought my EL... more room for the guns and ammo! Though I will say, my 0-60 get-away time slows a bit once I mount my dual .50 cals and stow 10k rounds of ammo for them.
Old 05-20-2009, 09:22 PM
poppie's Avatar
poppie
poppie is offline
Thanks!
----------------------------------------------NOT IF OBAMA CAN HELP IT,see 39.5 MPG story's, For the farmer's,contractor's,plumber's,electric contractor's,AC contractor's & RV'ER'S it's game over,the mouse truck's coming down the line just will not cut it hauling & towing big heavy load's.
Old 05-20-2009, 11:16 PM
carlos1212's Avatar
carlos1212
carlos1212 is offline
Ford should put the 6.2 in their Navigators.
There is no reason to buy a navigator over an expedition.
back in 99-02 navigators had an advantage over expy's because they had a 4v 300 hp vs the expy's 2v 260hp.
Now its the same engine and tranny.
Old 05-21-2009, 11:07 AM
gddyup's Avatar
gddyup
gddyup is offline
Right nebmike! I thought that was a given.
Old 05-21-2009, 11:41 AM
berry1234's Avatar
berry1234
And don't forget the bomb shelter!
Old 05-21-2009, 02:40 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
Our Expedition has the 5.4 and the trailer tow package. When I hook up to our travel trailer (approx. 8000lbs.) I don't have any issues with going or stopping. I do have issues with the rear suspension and maxing out my weight distribution hitch. Wish I could put some aftermarket air bags under there. Also, I have issues with stability at speeds over 60MPH. Windy days are not fun.
The engine/trans. really can't maintain 70mph in overdrive on flat ground with light winds. It constantly shifts in/out of overdrive and the slightest hill tips it into a lower gear.
So, I don't have any use for greater take off speed or faster 1/4 mile times. I wish the rear end were better suited for towing. More often than not, I just use my F250. Not a fair fight between the two so I won't even reference what life is like with the trailer behind my truck. I just grin and bear it when we go to FL or the Carolina beaches with the Expedition. Anywhere else, the truck goes.
Our Expedition is an '08, short XLT, 5.4 w/heavy duty tow package but I think the dang rear end is a 3.13. Oh well, got it for $26,500
Old 05-21-2009, 02:42 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
Oh yeah, the Smith & Wesson M&P 9mm rides with me.
Old 05-21-2009, 02:46 PM
gddyup's Avatar
gddyup
gddyup is offline
I have an 07 EL Limited.... my bomb shelter is portable!
Rush, there should be a metal tag attached to one of the cover bolts on the rear-end housing. You can find the gear ratio typically right off of that by checking the serial numbers on it. Can probably get the number and find the gear ratio online somewhere I would imagine....
Oh yeah, the M&P... nice pistolo!
Quick Reply: Will the Expedition get the 6.2l motor?
