460 stroker build and vid
Just got my 532 in and running good, been waiting for this for a long time
460 block from a '71 Lincoln, bored .080 over, cemented to the bottom of the water pump holes, oiling mods, Canton main stud girdle, ARP studs
Scat 4.3 stroke light weight forged crank
JE flat top pistons
Scat 6.8" H beam forged rods
Comp solid roller cam, isky lifters, Smith Bros push rods, Scorpion roller rockers, comp springs, Jomar girdle
Trickflow TFS Street heads, max ported, 2.25/1.76 valves
Victor intake
Demon 1095 carb, HVH super sucker 1" spacer
Canton pan/windage tray/crank scraper
YouTube - Firing up the 532ci BBF for a test run in the yard
JE flat top pistons
Victor intake
I just run a C6, as long as you use good quality clutches, a shift kit, and a massive cooler, they last a long time. This will be the last season for this transmission, if it lasts the whole season it'll get torn down and rebuilt again, and I'll be adding a manual valve body and a trans brake.
Bigfoot still uses C6s in a couple of their race trucks, #14 up until about 2 years ago was still runing one, so when built right they can definitly handle some serious abuse.
I missed my first race, but I have my next one on the 20th so we'll see how the first one goes, then I have about 3 or 4 more after that. I plan to run in atleast 2 classes at every event they will allow it, see if we can't run down some more competition!!
kjgibson2
05-17-2012 04:03 PM
F350 Strait
05-17-2010 01:21 PM
jamies460
19
06-07-2008 10:52 PM
shazam
15
01-11-2002 10:12 PM
