1964 F100 Factory Hood Scoop?
I'm picking up my truck tommorow. Was just looking to attach it but I guess I can't put attachments in my threads? Been without a truck for over a year. Sucks. That being said, has anyone ever seen a hood scoop mounted on an early 60s PU? It is off centered to the drivers side, its about 10"x10" with opening facing windshield and a 4" hole going down through the hood. The owner says that the Ford dealership confirmed it as a factory option but it was usually seen on the bigger work trucks for heat disipation. I think it looks pretty cool, especially if it is original. I've never seen one on any Ford.
Figured out the Pics....If you want to take a look at it its under Bws1964F100 in the Photo Album section.
Welcome to FTE
1961/66 F800/1100's with 401/477 and 534 gas engines came with a hood scoop.
1961/66: The scoop is mounted on the drivers side of the hood, its opening faces towards the windshield.
The F800/1100 hood has a large semi-rectangular hole in it, below that hole is an adapter that mounts directly to the trucks air cleaner, which is offset.
1961/66: The hood, scoop, aircleaner and attaching parts were not factory installed on F100/750's.
btw: The picture of the scoop Wally gives a link to in the post below, is on a 1967/72 F750/1100. The body style of F Series trucks changed in 1967.
gotahaveaford
Welcome to ( FTE ) !
Heres a picture of one on a big truck ! Different year but it may help !
link..>>>>>>>>>>>>>>>>>
https://www.ford-trucks.com/forums/7...n-f-600-a.html
Wally Womack
Wally Womack
B7QZ9671A .. Air Cleaner Duct (hood scoop) / Obsolete
Fits myriad F600 and larger trucks from 1957 thru 1972.
CENTRO CAMIONES in Vega Alta NA has ONE: 001-787-784-8000.
No one else has any.
B7TZ9672A .. Grille Assy - Use with Air Cleaner Duct / Obsolete
No Ford Dealer or obsolete parts vendor has any.
The 1955/57 T-Bird hood scoop is part of the hood itself, faces forward. The V shaped chrome grille bolts to the front of the scoop.
cschannuth
05-03-2008 05:43 PM
