Add-On Hood Scoop
Add-On Hood Scoop
Hey all,
I have an 89 F150. I have been looking for a scoop hood for a long time, but haven't found one for my particular model. I am thinking of buying an add on scoop that just bolts on to the factory hood, but I want that smooth finished look of the real scoop hoods. Is there any way that I could take body filler and fill the gap between the hood and scoop and sand it and paint it or would the filler just crack and look horrible?
Add-On Hood Scoop
Yup, you could add one to your hood, could use rivots or a 2 part epoxy. Yes you can fill it and make it look pretty, but with time you will most likely get stress crack especially if your 4 wheelin, twisting the body etc. Hoods are a big piece of sheet metal, thin and easy to tweak.
Add-On Hood Scoop
Use fiberglass reinforced filler on the seams. More resistant to cracking. You may want to try a functional scoop. It may take some fiddling to come up with something that seals to the hood on the inside (rubber seal), so try to get a used hood from the wreckers before hacking your own.
More power to ya!
Mark
More power to ya!
Mark
Rusty_Old_F250
Large Truck
10-24-2016 05:32 PM
lawdawg79
1999 to 2016 Super Duty
09-03-2015 09:17 AM
DustyRoadTruckinn
06-03-2015 12:43 AM
Mush's 88
Appearance & Dress-Up
05-08-2004 11:21 AM
