Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-15-2009, 09:30 AM
gottahaveaford's Avatar
gottahaveaford gottahaveaford is offline
1964 Ford F-100
gottahaveaford is starting off with a positive reputation.
1964 F100 Factory Hood Scoop?
I'm picking up my truck tommorow. Was just looking to attach it but I guess I can't put attachments in my threads? Been without a truck for over a year. Sucks. That being said, has anyone ever seen a hood scoop mounted on an early 60s PU? It is off centered to the drivers side, its about 10"x10" with opening facing windshield and a 4" hole going down through the hood. The owner says that the Ford dealership confirmed it as a factory option but it was usually seen on the bigger work trucks for heat disipation. I think it looks pretty cool, especially if it is original. I've never seen one on any Ford.
Figured out the Pics....If you want to take a look at it its under Bws1964F100 in the Photo Album section.
  #2 (permalink)
Old 05-15-2009, 05:51 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Welcome to FTE
1961/66 F800/1100's with 401/477 and 534 gas engines came with a hood scoop.
1961/66: The scoop is mounted on the drivers side of the hood, its opening faces towards the windshield.
The F800/1100 hood has a large semi-rectangular hole in it, below that hole is an adapter that mounts directly to the trucks air cleaner, which is offset.
1961/66: The hood, scoop, aircleaner and attaching parts were not factory installed on F100/750's.
btw: The picture of the scoop Wally gives a link to in the post below, is on a 1967/72 F750/1100. The body style of F Series trucks changed in 1967.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 05-15-2009, 05:54 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK Pro-Street/StateTK is offline
Garage is empty, add now
Pro-Street/StateTK is gaining momentum as a positive member of FTE.
gotahaveaford
Welcome to ( FTE ) !
Heres a picture of one on a big truck ! Different year but it may help !
link..>>>>>>>>>>>>>>>>>
http://www.ford-trucks.com/forums/73...n-f-600-a.html
Wally Womack
__________________
"Failure is an opportunity to begin again more intelligently" Henry Ford
My Pro-Street Article
  #4 (permalink)
Old 06-18-2009, 05:02 PM
Visalia65's Avatar
Visalia65 Visalia65 is offline
Visalia65 is starting off with a positive reputation.
yep...I gotta BUMP this! Anyone know where I can score one of these scoops?
Mike
  #5 (permalink)
Old 06-18-2009, 05:33 PM
gritsngumbo's Avatar
gritsngumbo gritsngumbo is offline
1961 Ford F-100
My Garage
gritsngumbo is gaining momentum as a positive member of FTE.
Looks almost like a 55-57 T-Bird scoop.
__________________
LITTLE RED: 64 F100 Short Style
BIG RED: 63 F100 Long Uni
BIG “UN: 63 F250 Long Flare
RUBY: 61 F100 CC BBW Long Uni
CRIMSON CREW 63 F100 "Stageway"
"RANGER" 66 F100 CC Long Flatbed
  #6 (permalink)
Old 06-18-2009, 06:47 PM
Ford Parts Guru
2013 Ford Escape
B7QZ9671A .. Air Cleaner Duct (hood scoop) / Obsolete
Fits myriad F600 and larger trucks from 1957 thru 1972.
CENTRO CAMIONES in Vega Alta NA has ONE: 001-787-784-8000.
No one else has any.
B7TZ9672A .. Grille Assy - Use with Air Cleaner Duct / Obsolete
No Ford Dealer or obsolete parts vendor has any.
The 1955/57 T-Bird hood scoop is part of the hood itself, faces forward. The V shaped chrome grille bolts to the front of the scoop.
__________________
  #7 (permalink)
Old 06-20-2009, 05:26 PM
drof46's Avatar
drof46 drof46 is offline
drof46 is starting off with a positive reputation.
Just buy a spare hood and add scoop/s. You can buy them from summit.
__________________
1966 F-100 Custom Cab (work in progress)
351 Cleveland 4V (DOAE-J) *No its not a 351M**
C4 trans, 3.50 trac loc installed.
Ground up resto. Ground is done, ran out of money for the up.
Tags
1961, 1964, 57, bed, big, bird, cheap, f100, factory, ford, hood, options, scoop, scoops, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
