Auto to manual transmission swap
Old 05-15-2009, 01:42 AM
nextalcupfan's Avatar
nextalcupfan
nextalcupfan is offline
im lookin at a 1996 f-150 with a 5.8L 351W 4x4 supercab with an auto transmission.
i was wondering what kind of effort it would take to swap it out to a manual.
would i need to swap the computer?
what about cruise (sp?) control?
whats a good 5-speed manual tranny?
i also dont know the rear axle ratios yet.
i know it would be alot of work but this truck is really nice except for the auto tranny.
ty
Old 05-15-2009, 02:31 AM
froddinjarebear's Avatar
froddinjarebear
froddinjarebear is offline
its not extremely hard to do. you will need a new computer, transmission harness, clutch flywheel, backing plate? maybe a new starter? i wouldn't use the tranny out of an f-150 what you wanna find is a zf 5spd its found in f-250's and f-350's and your gonna need one that had either a 4.9, 5.0 or 5.8 behind it so the bell housing will work. and you will probably also need new drive shafts although i cant say that for sure.
Old 05-15-2009, 08:16 AM
nextalcupfan
why would i need a new harness?
what is controlled by the computer in a manual tranny?
Old 05-15-2009, 08:21 AM
rostena's Avatar
rostena
rostena is offline
https://www.ford-trucks.com/forums/8...azda-m5r2.html
That should be all the info you need.
Old 05-15-2009, 08:39 AM
nextalcupfan
thx that was a lot of help
Old 05-15-2009, 08:47 AM
jas88's Avatar
jas88
jas88 is offline
Here's a pic somebody sent me when I did mine, I found this very helpful:
You will want to use a ZF trans behind the 351.
Old 05-15-2009, 11:58 AM
Alvin in AZ's Avatar
Alvin in AZ
Alvin in AZ is offline
I don't know. :/
But I do keep seeing where you need to change that stuff out.
And I also keep reading where you don't need to do anything other
than fool the "automatic computer" into thinking the transmission is
in neutral.
Pros and cons from the two different methods would be cool to
know if anyone's every really worked out what those are. :)
Alvin in AZ
Old 05-15-2009, 12:41 PM
jas88's Avatar
jas88
jas88 is offline
The harness for a ZF only goes to the switch for the backup lights - you could probably make that yourself if you had to.
You don't have to swap the ECM if you don't want to, but it will give you several (8 as I recall) codes complaining about how the trans is not talking to it.
Old 05-19-2009, 08:00 AM
nextalcupfan
thx for all the help
how much h.p and torque do u think the zf-5 will hold?
Old 05-19-2009, 08:19 AM
rostena's Avatar
rostena
rostena is offline
Alot. I think you could do some very serious modding before you have to worry about the ZF's limits. Its a stout trans. They put it behind 460's and deisels.
Old 05-19-2009, 01:56 PM
Alvin in AZ
ZF S5-42 is rated to handle 420 foot pounds for the life of the truck.
ZF S5-47 is rated to handle 470 foot pounds for the life of the truck.
My '90 F250 parts truck with a 5.8 has the ZF S5-42.
My plan is to put a -plain Jane- "408" (351W 4" stroker) in front of it.
Not sure what mods I'll end up with but, the plan is to use a low-end
torque cam and that's it.
"a 300 I6 with two more cylinders" LOL :)
-Not- a friggin "racing engine" danggit! :/
YMMV ;)
Alvin in AZ
Old 05-19-2009, 02:00 PM
Alvin in AZ
{cool :}
Hmmm...
That doesn't sound good if those have the effect of teaching
the computer to make changes to the operation of the engine. :/
Thanks for your reply, Jas. :)
Alvin in AZ
Old 09-29-2009, 09:46 AM
nextalcupfan
will a ZF trans bolt up to a 300 six or a 302?
In both 2WD and 4WD applications
Old 09-29-2009, 11:00 AM
Alvin in AZ
Yes, if the ZF has the "right" built-on bell housing for them and
the 351w, which are all (for the most part) the same pattern.
Alvin in AZ
Old 09-29-2009, 08:32 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
^^^^ Not just "for the most part." They ARE the same pattern. Any trans put behind an I-6 or 302 will bolt up to a 351W, and vice versa.
Quick Reply: Auto to manual transmission swap
